Help with wireless network
The PCI gives me an antenna - I'm a good distance from the wireless hub, but still get great reception with it.
I also got it on ebay, new - so i can't exactly return it
I also don't have USB 2 so my speeds with a usb adapter would be slow
Originally Posted by joebenz
first i'd call up d-link to see what they say.
- the wait takes forever
- they have to get their customers off the phone by 15 minutes (solution or not)
- most of them will brush you off with an answer like "buy a new one"
I would know, I was working for their tech support
h:Try setting a static IP address 1st
no sig
no sig
The thing with windows XP, it has its own built in wireless utility.
Are you using that utility or D-Links utility?
Sometimes when you have both itll start causing connection drops, connection drops while doing large file transfers.
I'd say use one or the other. If you want to use the D-Link utility than completely disable the XP utility (you have to go into your computer management). If you want to use the XP utility (which is very user friendly) you can uninstall the D-Link utility. Also make sure not to have any firewall software enabled (depending on how secure the network is) because routers tend to have a built-in firewall
I've tried both windows, and D-links - both work the same...
I'll go disable window,s and use d-link - I like D-links setup better - i can see signal strength and whatnot...
I have my firewall disable already
westcoaststyle
Dec 29, 2003 01:49 PM
rb6teg
Jul 7, 2003 08:59 AM
