Hard drive jumper settings?
Its been a while since I have added any hard drives or swapped any around so I need to know what the master pin setting is on a Maxtor drive.....can't seem to find the paperwork around anywhere.
should be jumper 50 should be master. that is the one closest to the ide connector
'00 Dakar Bus CRS Edition
LCD Squad #0001
LCD Squad #0001
Originally Posted by WiLL
:::::::::::::::::::---:::.:---oooo
The first 40 = ide signal pins the next 3 should be the master/slave/cable select, the next two are not used and the last 4 are the cable
you want a jumper on the bolded pins
LCD Squad #0001
LCD Squad #0001
Thanks Rick.
I checked the drive out and wouldn't have asked if it was simply labeled on the top of the drive
Thanks Rick.
no problem
also with maxtor drives if you flip the drive over and look at the silk screening on the board they usually have it labeled
ms for master, sl for slave, etc
LCD Squad #0001
LCD Squad #0001
Originally Posted by DakarM
no problem
Greddy Guy
Oct 9, 2002 07:40 PM
