PC problems
Old Jan 24, 2004 | 03:28 PM
DarkSideAccord's Avatar
DarkSideAccord
Chidori-chan :love:
Default PC problems
Alrite.. here's the situation... i got a new motherboard, CPU, and hard drive... everything works fine, but i have problems installing an OS on the hard drive... my friend put my hard drive into his PC and he successfully installed windows XP... it worked fine with his system...
then, i put it back into my system and it has problems loading the OS... the screen says "Error loading OS"... wat's up with that?? :thinking: i've checked all the jumpers and connections and it still wouldn't load.. my guess is the motherboard is ****ed up... it's an ASUS and it's new.. shouldn't be a problem rite?? pls help.. thanx
Old Jan 24, 2004 | 03:44 PM
wedley2's Avatar
wedley2
bboy Wesley West
kinda need specs of the whole thing, how many times have you tried it?
Old Jan 24, 2004 | 03:46 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
with the exception of the Corperate versoin of XP, when it loads, it takes a 'snapshot' of your hardware profile. If it is dramatically different, it won't load, or it will ask you to re-activate it.
The problems your having is probably related to a bad IDE connection. Check all your cables, try a diff IDE plug/port and then try a new wire. Make sure its all functioning and setup correct.
Reformated, and reinstall the OS when its in YOUR box.
XxRONNxX
Accord
8
Nov 11, 2002 06:51 AM
steveng
6
Sep 10, 2002 03:11 PM
snail
92+ Civic/EL & Del Sol
4
Sep 9, 2002 08:54 PM
ant6177
4
Sep 5, 2002 08:05 AM
JackoliciousLeg
13
Jul 30, 2002 05:20 PM
