hey guys help
Old Jan 10, 2008 | 08:01 PM
Niceprelude's Avatar
Niceprelude
Default hey guys help
Hi guys,please help both happen at the same time first the heat is gone and second its leaking coolant behind the engine around the top of oil filter area im know its not the hoses for sure.what is wrong.
Old Jan 10, 2008 | 09:15 PM
nspec_Cd5's Avatar
nspec_Cd5
heat could be teh cable problem. look infront of the firewall (right behind the motor) u'll see a coolant hose going in the firewall w/ a little lever on it and a cable going to the lever, when u turn the temperature knob to heat position, the cable pulls the lever and opens up the valve and that lets the hot coolant/water go in to ur heater core.
if it doesnt move when u turn the temp knob, then u have a broken/disconnected cable.
It has to be a coolant hose going from the back of the motor where teh coolant is leeking.
Old Jan 10, 2008 | 09:47 PM
Niceprelude
I check it is not the hose maybe its the coolant going inside the engine coming out
Old Jan 23, 2008 | 08:47 AM
asheylarry's Avatar
asheylarry
fix the leak then worry about the heat problem. you probably have a leaking heatercore inlet hose. if it leaks, then coolant isnt making it to the heatercore. then you get no hot air. fix the leak first
Old Jan 23, 2008 | 06:57 PM
Niceprelude
The leaks i see is not the hose,its behind the engine and above the oil filter area. What you think it is.
Old Jan 23, 2008 | 08:51 PM
Line7's Avatar
Line7
Platinum Member
Water pump, if it's not a hose.
Old Jan 23, 2008 | 11:18 PM
Niceprelude
look like the leak come out behind the wall of the engine.the heat and leak happen at the same time.
Old Jul 21, 2025 | 09:10 AM
daryelcorran's Avatar
daryelcorran
eddie1984
Accord
Apr 26, 2008 05:32 PM
ferio7
92+ Civic/EL & Del Sol
5
Nov 13, 2005 07:32 PM
jmg
Minivan, SUV, & Truck
2
Mar 23, 2005 05:23 PM
1CleanLS
11
Jul 26, 2004 06:04 PM
civicon19s
Engine Swaps, Tech & Tuning
8
Nov 7, 2002 08:46 AM
