idle problem
Old Mar 9, 2007 | 09:45 PM
TheImportsRacer's Avatar
TheImportsRacer
internet hax0r elite
Originally Posted by 92CivicPrelude
Yea my car does about the same thing bounces up and down from 1-1 1/2to about 2.But when its warmed up it runs fine.
simple. IACV. my integra did the same thing. cleaned out the IACV and tightened it up, problem solved.
Old Mar 9, 2007 | 09:47 PM
TheImportsRacer
Originally Posted by jdmeg6hatchy
when my car warms up the idl is fine, until then it bounces from 1200-1500rpm
your IACV is bad. my teg did this. my friend myron showed me a work around. we cleaned the IACV, then he tightened it, but not all the way. stuck it back in and the car idles perfectly...
well at least it did till i sold it. no clue what its doing now
Old Mar 13, 2007 | 07:55 PM
92CivicPrelude's Avatar
92CivicPrelude
i cleaned out the iacv and idle still bounces...i found a vacuum and it still bounces so my boy told me to take the intake off ands plug the top hole on the throttle with my finger and then the car runs fine. so i geuss i have to bypass the cold start. what do u think???
Old Mar 13, 2007 | 10:27 PM
TheImportsRacer
mines the exact sam way. i plug that hole and the idle is fine. i need to find out how to bypass that and id be good.
Old Mar 15, 2007 | 11:11 AM
92CivicPrelude
well there is a ivac on the front of manifold... i pulled mine out and cleaned it with some carb cleaner and it running alot better... and i cleaned the throttle body..... i also bypassed the cold start..which is take the hoses off the ivac both under the throttle body and the one on the manifold. simple i just ran the hose from the block back to the block..any qeustions just ask
Old Mar 15, 2007 | 11:13 AM
TheImportsRacer
do you have pictures on how you bypassed the cold start? if i do that im sure ill solve my idle problem, as i thnk thats what my friend did with my integra...
Old Mar 17, 2007 | 06:39 AM
92CivicPrelude
it's real simple to do......... first make sure your antifreeze isn't hot.... alright there is two hoses going to the bottom piece attached to the throttle body.. i believe it's ur ivac.....there is also anothere i vac i think is is anyway but it's on the front of the manifold...it's held on by two bolts.. simple get rid of the hoses....(should also clean these parts with some carb cleaner.while u have them off).....basically check to see how the hoses run.... after that find where it comes from on the block and also where it goes back to the block...once u find that all u have to do is take one of the hoses u just took off and find one long enough to run from block to block...i would keep all the stuff u took off for winter time to reverrse the process.. any more qeustions feel free to ask
Old Mar 17, 2007 | 06:47 AM
92CivicPrelude
check this forum out this guy tells alot about the h22
http://www.attackforums.com/showthread.php?t=1197
Old Mar 17, 2007 | 11:51 AM
TheImportsRacer
ghey theres a link on those forums to another one that has the information i need and its a pay site. GHEY!
on a side note, i think i located those 2 hoses. i think one of them can fit the entire length like you said. ill give it a shot
Old Mar 17, 2007 | 12:46 PM
92CivicPrelude
yea try let me know what's up..............
