car wont start.
Old Oct 26, 2006 | 03:22 PM
jdmhondalude22's Avatar
jdmhondalude22
Default car wont start.
i have spark, i can hear the fuel pump, but the injectors are not spraying.
Old Oct 26, 2006 | 04:52 PM
Fuse's Avatar
Fuse
what year.
Old Oct 26, 2006 | 05:49 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Main Fuel Relay
Old Oct 27, 2006 | 02:52 AM
jdmhondalude22
92 with h22a. fuel pump turns on for the 2 seconds and then turns back off, so therefor, doesnt that mean the main fuel relay is working.
the car sat for a good week while i did the motor swap. started right up and ran fine for 30 minutes, then i drove it for about 20 minutes, then it died on me. after it stalled out, it sat for 10 minutes, started up and stalled back out. sat for 3 hours, started up, stalled back out. ???
fuel IS getting to the fuel rail.
Old Oct 27, 2006 | 05:33 AM
ionascu14's Avatar
ionascu14
Default Double Check all ground connections
Find as many grounding wires as you can, and make sure all the spots where they ground are clean and tight!
Make sure you are getting enough fuel pressure to the rail. (36 to 40 lb.) Pump may be weak, or even, more possibly the fuel filter is restricted and causing low pressure. It sounds more like the filter is the trouble. It's clogging as you drive, and after it sits a while the dirt settles,and then it will run again for a short time.
Main realy could be the problem also, but good luck replacing it. The easiest way is to remove the screws along the top dash rail, unclip the black face plate, and then the speedometer/tach unit. You can get to the bolt then, possibly!
But if all that stuff is OK, then check the injector relay!!! It's at the left rear corner of the engine compartment. Good luck!
Old Oct 27, 2006 | 06:23 AM
Fuse's Avatar
Fuse
it could be the injector resistor box but i need to know what year to tell if it has one.it could also be everything stated before.
Old Oct 27, 2006 | 09:56 AM
jdmhondalude22
its a 92 with a 94 h22a.
ok, so i have codes... 4- ckp sensor 16- fuel injector system 41- o2 sensor-heat (whatever that means). i changed out the distributor. now i have codes 15-ignition output signal and 41 still. car still wont start. ???
Old Oct 27, 2006 | 01:42 PM
Fuse's Avatar
Fuse
its ether the imc(ignition control Modula) the coil or broken wires.the imc aka igniter is the little box with 4 wires ruining to it under the dizzy.so change out the imc and the coil from the old dizzy (the one with the bad ckp sensor)and check for broken wires.the code 41 is the 02 sensor or broken wires but would still run good with that code.is it a new dizzy or a used one.you probably flooded the car so next start up attempt hold the gas to the floor.
Old Oct 27, 2006 | 03:09 PM
jdmhondalude22
well i switched the dizzy for the 3rd time. i know this one is good. i have codes 16 and 41. 16 being fuel injector systems. car isnt flooded because i am getting absolutly no fuel throught any of the 4 injectors. more help.
Old Oct 27, 2006 | 03:21 PM
Fuse's Avatar
Fuse
ok code 16 is the injector the injector resistor,wiring or the ecm.you can check the injectors you should have 1.5 to 2.5 ohms on each injector.the injector resister looks like this.its strange you codes keep changing with diferent dizzys.i have seen the injector resistors go bad.
