car wont start.
Old Oct 27, 2006 | 04:00 PM
Fuse's Avatar
Fuse
dont give up i have the hole book on that car.
Old Oct 28, 2006 | 07:27 AM
jdmhondalude22's Avatar
jdmhondalude22
changed the resistors... no luck still
Old Oct 28, 2006 | 03:37 PM
Fuse's Avatar
Fuse
SHIT you still get code 16.
Old Oct 28, 2006 | 03:45 PM
Fuse's Avatar
Fuse
ok fuck the book lets dive in.check fuse 4 under dash.then i need to see if you have 12 volts at the red wire to the injector resistor key on.if you do its the injectors or the ecm or broken wires.if you DONT it would be the main relay or a cut power wire i have never seen a main relay stop injector pulse just fuel pump power supply.below is the pgm-fi from my book.let me know if we have 12v ther is still a lot of diag we have to do so dont change out any more parts sorry we will get this fixed.
Old Oct 28, 2006 | 05:52 PM
Fuse's Avatar
Fuse
ok im going to take it a couple of steps farther to check the main relay.check fuses 4 23 19 see if you have 12 volts at the yel/blu and the blk/yel key on. do a continuity test on the black wire.so if it doesn't have 12v at blk/yel or yel/blu you have a bad fuse or a broken wire.if it failles the continuity test you ground is not connected.if it pases the 12v test and the continuity test but you dont get 12v and the red wire on the injector resistor its the main relay or an open from the relay to the injector resistor.
Old Oct 28, 2006 | 05:55 PM
Fuse's Avatar
Fuse
ok if you get 12v at the red wire at the injector resistor but still have no injector puls check to see if you have 12v at each red/blk wire to the injectors.if you don't you have a open from the injector resistor to the injectors. if you do check the ohms on the injectors 1.5 ot 2.5 ohms.ok if that passes you will need to do a continuity test from the injectors control side to the computer take the computer connectors off first if you get continuity is the computer if you don't you have a open in the wires from the injectors to the computer.
Old Oct 28, 2006 | 06:00 PM
Fuse's Avatar
Fuse
sorry this all sound really confusing(and is a big pain in the ass) just print out the diagram and look at it for a while you will get it.
Old Oct 30, 2006 | 03:00 AM
jdmhondalude22
hey thanks for all this help. im going to try to come up with the things i need to test all that stuff throughout today.
Old Oct 30, 2006 | 04:05 PM
Fuse's Avatar
Fuse
you will just need a meter i think just start with the 12v at the red wire let me know. i will alway reply some times it takes a wile.
Old Nov 7, 2006 | 06:56 AM
jdmhondalude22
got car running. broken wire to the distributor. poor connection.
still have codes 16 and 41. and now i have code 21 and code 43 as well. code 21 is weird cuz vtec still crossesover. ???
