turbo problems
Old Sep 14, 2002 | 10:58 PM
turbo-luder01's Avatar
turbo-luder01
Default turbo problems
I recently had a drag turbo kit installed on my 01 lude. It was running fine, then all of a sudden i was driving on the freeway and, now i cant make boost. At wider throttle postions the car has no power it seems like. Could this be due to a problem with my fuel system? Also, does the timing of my engine have to be retarded or advanced or something?i Had my timing retarded when i had my cam gears put on a while back,does it have to be redone?
Old Sep 14, 2002 | 11:26 PM
nosaccord2k's Avatar
nosaccord2k
Does the car boost at all? Does it just boost a lot lower than before, or does it not boost at all? There might be a problem with your wastegate, Deltagate wastegates seem to always have some sort of trouble. (i think that's the wastegate that comes with the drag kit). Perhaps the wastegate is opening way too early for some reason? Check the vaccum hose that connects to the lower "boost" port on the wastegate, make sure it isn't kinked, off, cracked, etc... You may also have a leak somewhere, say at a connector boot between pipes, that can bleed boost also. Also, maybe check the blow off valve, perhaps it's staying open, and bleeding off boost for some reason.
Lastly, do you notice the car pull as if it were boosting, but the boost gauge isn't reading boost? If so, then the problem wouldn't be with your motor, but something simple to do with the vaccum line between the motor and the gauge.
hope some of this helps.....
littleguy_77
Minivan, SUV, & Truck
Nov 30, 2008 06:34 PM
mikeunreal
92+ Civic/EL & Del Sol
Oct 19, 2005 10:11 PM
speedshifter101
CRX & Pre 92 Civic
4
Jan 15, 2005 05:30 AM
blackstar
Accord
15
Oct 30, 2004 01:04 PM
sick79
CRX & Pre 92 Civic
Jan 13, 2004 10:53 PM
