Gas mileage???
Old Dec 31, 2005 | 10:41 AM
  #31
NUUUBIELUDDIE's Avatar
NUUUBIELUDDIE
NM i know what they are, basically the same. I should of just googled it. Thanks for the help guyyszzzz
Old Dec 31, 2005 | 12:59 PM
  #32
eric_enciso's Avatar
eric_enciso
no prob
Old Jan 2, 2006 | 06:08 AM
  #33
mybluelude's Avatar
mybluelude
WILD BILL
Originally Posted by Phateless
injector cleaner is like 5 bucks at chevron. that B&G 44K shit is pricey tho, it's like $20-$30. just run regular injector cleaner from any gas station, put it in on an empty tank and drive around for a day or two, then fill up with premium. might help, couldn't hurt.
I HAVE HEARD THAT PUTTING INJECTOR CLEANER IN AN EMPTY TANK CAN BE BAD ON FUEL LINES AND INJECTORS, AS IT IS A VERY CAUSTIC SUBSTANCE, I WOULD RUN AT LEAST HALF TO THREE QUATERS OF A TANK WITH THE INJECTOR CLEANER, BERRYMAN B-12 HAS ALWAYS WORKED GOOD FOR ME, BUT THERE ARE SOME NEW THINGS ON THE MARKET, READ THE LABEL FIRST. HOWEVER, IF IT'S THAT BAD ON GAS MILAGE I'M THINKING THAT IT PROBBABLY NEEDS TO BE PROFFESIONALLY TUNED! YOU SHOULD GET WAY MORE MILEAGE THAN THAT!!!
Old Jan 2, 2006 | 07:29 PM
  #34
ludeboom's Avatar
ludeboom
Originally Posted by 2.2L
damn that sux. Best i have gotten is 370 with my h22a. i average around 330-340 and i have about 2 gallons left when i fill up.
thats about what i used to get on a road trip with no vtec in 5th.
one time i did 120 for about 4-5 minutes and ate about 1/3 to 1/2 tank.
Originally Posted by mybluelude
On Another Note, I Am Rebuilding The Front And Rear Suspension, In As Far As Energy Suspensions Black Graphite Poly Urethane Bushings, I Got The Whole Kit, Motor Mount Inserts Too! I Haven't Bought New Tires Yet, But They Are Badly Worn, I Talked To The Alignment Shop About What This Could Mean. They Are Suggesting Adjustable Ball Joints. Any Suggestions From Ya'll Would Be Welcome. I Probably Need To Do The Rear As Well.
is the car lowered?
i think you will be unhappy with the ES kit if you drive the car on a commute everyday. Although i must say it is a great thing at track day.
Old May 17, 2008 | 01:55 AM
  #35
shandonwall's Avatar
shandonwall
EG man!!
95 SI 2.3 best so far is a documented 30.2 mpg
