Gas mileage???
Old Dec 29, 2005 | 10:05 PM
Phateless's Avatar
Phateless
S2K compatible
injector cleaner is like 5 bucks at chevron. that B&G 44K shit is pricey tho, it's like $20-$30. just run regular injector cleaner from any gas station, put it in on an empty tank and drive around for a day or two, then fill up with premium. might help, couldn't hurt.
Old Dec 30, 2005 | 02:53 AM
jdm-power's Avatar
jdm-power
try to change the place u get ur gas from....i remember i always used to fill up with BP gasoline 93 octane and i wount even touch the 250 mark with my whole tank. then i switched over to Shell V-Power gas and remarkably i averaged around 370-380 whole tank...
try doing that....worked for me...
Old Dec 30, 2005 | 12:29 PM
NUUUBIELUDDIE's Avatar
NUUUBIELUDDIE
Let me try that i still have a half tank of gas left right now. Im using gas from like arco.. I've heard a few times now that people get more mpg with shell Vpower..i should give it a try.
NUUUBIELUDDIE
Whats the differnce? Is one brand better than the other? and if i use the fuel injector stuff should i use it when im on a full tank?
Old Dec 30, 2005 | 01:41 PM
Phateless's Avatar
Phateless
S2K compatible
the 44K is supposed to be the best. that's what all the techs at the honda dealer i work for tell me. there's no octane in it tho, so if you run it on an empty tank, your car will run like shit. if you add octane booster at the same time you'll probably be ok tho.
Old Dec 30, 2005 | 04:32 PM
NUUUBIELUDDIE
Well i went to go buy a bottle of fuel injector cleaner and i came across a fuel injector cleaner and a fuel system cleaner and some other bottles that were about the same. Whats the difference between fuel system cleaner and fuel injection cleaner? ( I didn't buy one becuase i didnt know what there differences are) Are they both the same? And by the way, most were under $5.
Old Dec 30, 2005 | 04:33 PM
NUUUBIELUDDIE
the 44K is supposed to be the best. that's what all the techs at the Honda dealer i work for tell me. there's no octane in it tho, so if you run it on an empty tank, your car will run like shit. if you add octane booster at the same time you'll probably be OK tho.
If i choose to use 44k what will happen if i dint use any octane with a empty tank of gas? What if i have a full tank of gas? Will there be internal damage? I saw some octane booster when i went to go buy some...What does that do? I am sorry for these questions i don't know much about anything
Old Dec 30, 2005 | 05:12 PM
Phateless's Avatar
Phateless
S2K compatible
this is a 1994 base model, right? NOT Si? then fuckit, you don't need to worry about it. just run it straight.
Old Dec 31, 2005 | 10:30 AM
prelood's Avatar
prelood
I got horrible gas milage in mine. (97 h22)
250-300 miles/tank
Old Dec 31, 2005 | 10:37 AM
NUUUBIELUDDIE
So you mean it doesnt matter if i have full or empty tank kk thanks.....Whats the diff between fuel system cleaner and fuel injector cleaner?
