17' or 18' Inch Rims ?
Old Mar 10, 2004 | 01:38 AM
SwiftStreetLude's Avatar
SwiftStreetLude
Default 17' or 18' Inch Rims ?
Sup fellas ... I just recently got a blue 2k1 Prelude SH. I was wondering, which size rims should i go with? 17's or 18's. Is there pros and cons of the two? What size is everyone rolling on and what gen prelude do you have?
Thanks.
.:Swift:.
Old Mar 10, 2004 | 03:51 AM
joostdyk's Avatar
joostdyk
eluded si
well either one will work, depends what you like and want. i have 17's on my 4 gen. i would never go bigger than that personally just because of the extra weight and increased changes of rubbing. i'm sure there are a couple threads on this already though so you might want to check those out if you can find them.
Old Mar 10, 2004 | 10:18 AM
Pelka's Avatar
Pelka
::..Prelude..::
Ditto.
Old Mar 10, 2004 | 05:07 PM
MTLuda's Avatar
MTLuda
With a 2001, I like the look of 18s. However, you may have more trouble with them, mainly because of the 35 series tires youd have to buy to fit the wheel well. If you live or drive on roads with any potholes, youre screwed. I have replaced a rim and sent another off to get the bends taken out of it. However, I put a lot of miles on mine. It is a longer car than the 4th gen, so the 18" rims set it off better than 17s would. But, thats just my opinion.
Old Mar 10, 2004 | 06:03 PM
monkey's Avatar
monkey
#212
17's over 18's.
16's over 17's.
17's vs. 18's:
17's will be faster, brake better, handle better, not get damaged as easy, cheaper, cheaper to buy tires for, not so ridiculous looking, will not rub as much.
18's look tacky, especially with all of that clearance between the brake assembly and the wheel. If you're gonna go 18's go 18's for a reason...get the biggest F'in brakes you can find.
16's are superior to either because of even better accel, brake, cornering (depending on your tire choice) etc etc.
Old Mar 11, 2004 | 01:39 AM
SwiftStreetLude
Thanks for the info. I think ima go with 17's. I wanna get those new Konig Freefall's, but on wheelsnext.com, it says they arent available for the Honda Prelude. But that cant be right.
Here's the link:
http://www.wheelsnext.com/product.phtml?p=965
.:Swift:.
Old Mar 11, 2004 | 04:49 PM
4thgenlude's Avatar
4thgenlude
I got some 17s, but i wish i had got 16s, so if i were you i go with the 16s, unless youre going for a show car
gAmEs0n
Aug 16, 2003 10:59 AM
gAmEs0n
Aug 7, 2003 05:03 PM
narib_16
92+ Civic/EL & Del Sol
20
Jul 18, 2003 12:36 PM
ElectronBlueGSR
Nov 23, 2002 04:51 PM
