selling LsVtec
I have the following parts in my garage, and would like to sell them to pay for school.
Bottom end
cleaned B18A block and crank
new P73 (Integra Type R) Pistons w/wrist pins
new Z10 Engineering crank girdle
new ITR oil pickup and windage tray
PR4 rods w/ polished beams
new vtec oil pump, water pump and timing belt
new oem crank and rod bearings
ARP Rod bolts
new main bolts
new piston rings
OEM pully and flywheel
complete oem bottom end gasket set for b18a
top end
B16A cylinder head w/ >60,000 KM
B16A Intake and Exhaust Cam
Black Valve cover w/ D O H C shaved off
VTEC
B16A Intake Manifold complete w/ sensors, rail, injectors and tb
B18A Exhaust Manifold
PR3 Distributor
New OEM Vtec head bolts
new oem gasket set for top end (minus head gasket and valve stem seals)
+I'm sure there are other parts I've forgotten. All you'd need to make an LsVtec is the head gasket,
the external oil lines, and most of the machine work done. Will sell it all to the best offer.
Bottom end
ARP Rod bolts
new main bolts
new piston rings
top end
VTEC
PR3 Distributor
