Average Mileage of Hondas
Old Feb 16, 2006 | 12:47 PM
ISP James's Avatar
ISP James
DAMIMRED
94 integra LS
221k
rarely driven but runs strong.
Old Feb 16, 2006 | 02:50 PM
wil4713's Avatar
wil4713
95 accord ex. 108k; no problems.
Old Feb 17, 2006 | 04:59 PM
maverick_990's Avatar
maverick_990
I have 262,000 on my 1989 Honda Civic Hatch Si and still running strong
Old Feb 20, 2006 | 09:15 AM
mr.crx's Avatar
mr.crx
my crx has 230,xxx miles, my integra had about 210,xxx before the swap, and my old crx had about 240,xxx before the swap
Old Feb 20, 2006 | 09:19 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
my Accord is tipping 90K ... it runs great and I hope it keeps going. It's finally paid off this December.
You're due for a tranny in 50-60k miles :chuckles: h: Clean out the EGR ports yet?
Old Feb 20, 2006 | 09:58 AM
not yet :hs:
March 10th
timing belt
all drive belts
water pump
clear the CEL (I believe this is an O2 sensor issue)
My tax refund goes away almost instantly.
Old Feb 20, 2006 | 11:31 AM
98CoupeV6's Avatar
98CoupeV6
not yet :hs:
March 10th
timing belt
all drive belts
water pump
What's the MIL Code?
Doing the t-belt/pump yourself? I'm almost due for that. I'll let it go until 240 or so, I did it the first time at 125. I've been procrastinating on changing my PS pump belt because I have to jack up the engine.
Old Feb 20, 2006 | 11:54 AM
jaje's Avatar
jaje
HC Racer H5
1985 Prelude ~275k miles (just maintenance and wear/tear)
1992 Prelude ~150k miles (just maintenance and wear/tear)
1989 Accord LXi ~175k miles (just maintenance and wear/tear)
1988 CRX HF ~315k miles (just maintenance and wear/tear) - (swapped in Si engine at 310k then sold the car
rotary guys are becoming rarer as they just don't last as long...it's about 30k before a rebuild of the motor is needed as the apex seals just die so quickly...honda 4 cyl engines are just bulletproof for durability and abuse they will take
Kai is a moderator here and works on both rotary and is a Honda Tech - he can vouch for longevity
Old Feb 20, 2006 | 12:26 PM
Grifter's Avatar
Grifter
2000 civic si nearing 100k
Old Feb 21, 2006 | 12:35 AM
Phateless's Avatar
Phateless
S2K compatible
94 accord 160k
95 teg LS 175k
all going strong, just regular maintenance
