News & Rumors Archives Useful threads, previous Cars of the Week, and more.
Mitsubishi Lancer Evolution MIEV - check it out, an electric Evo!
Old Aug 24, 2005 | 05:04 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Default Mitsubishi Lancer Evolution MIEV - check it out, an electric Evo!
Tokyo, August 24, 2005 — Mitsubishi Motors Corporation announced that it would enter a Lancer Evolution MIEV1 test vehicle in the Shikoku EV Rally 2005 to be held August 27-28 in Tokushima Prefecture on the island of Shikoku, Japan. Deriving from the Company’s Lancer Evolution IX high-performance 4WD sports sedan, Lancer Evolution MIEV uses a lithium-ion battery system to power four newly developed in-wheel motors. The Shikoku EV Rally 2005 is organized by the Shikoku EV Challenge Committee and the Shikoku EV Rally 2005 Executive Committee.
Mitsubishi Motors is driving forward the development of the Mitsubishi In-wheel motor Electric Vehicle (MIEV) next-generation electric vehicle and is planning to bring a MIEV model, built around core technologies of in-wheel motors and high density lithium-ion batteries, to market by 2010.
The Lancer Evolution MIEV will be the Company’s second MIEV test vehicle, following the Colt EV announced in May 2005. The new in-wheel motor uses a hollow doughnut construction that locates the rotor outside the stator as opposed to a common electric motor where the rotor turns inside the stator. This construction brings several benefits. It makes it easier to raise power output and torque; higher torque allows the speed reducer unit to be eliminated, which means less weight and improved power transmission efficiency; and it offers better space efficiency with the brake assembly fitting inside the motor which itself fits neatly within the wheel house. The outer-rotor arrangement also surmounts the difficulties presented to date by the steering system, making it suitable for fitting to and driving the front wheels that opened the way to 4WD in-wheel motor vehicles.
Mitsubishi Motors has acquired vehicle type certification for Lancer Evolution MIEV and will be conducting practicality evaluations over a wide variety of conditions, the Shikoku EV Rally and other public road driving included. The evaluation programs will assist the Company in developing high-performance electric, hybrid and fuel cell vehicles that deliver not only superior environmental performance but also output performance and maneuverability equal to or better than gasoline-fueled vehicles.
1 Mitsubishi In-wheel motor Electric Vehicle
Lancer Evolution MIEV: overview
Mitsubishi Motors’ MIEV concept comprises two core technologies: lithium-ion batteries, which the Company has been developing for practical application in automobiles; and the in-wheel motor that, as its name implies, mounts inside the vehicle wheels. Building upon the advantages offered by these technologies, the MIEV concept is currently the main driving force behind the Company’s development of next-generation electric vehicles. Mitsubishi Motors also envisages the application of the MIEV concept in hybrid and fuel cell vehicles. The first MIEV test vehicle built by Mitsubishi Motors for in-wheel drive system development and testing purposes was the Colt EV, announced in May 2005. Derived from the standard production Colt compact model, Colt EV is driven by in-wheel motors mounted on the rear wheels and powered by a lithium-ion battery system.
With the Lancer Evolution MIEV high-performance 4WD in-wheel motor test vehicle, the Company has taken the next step forward. After removing the engine, fuel tank, transmission, differential, drive shaft and other 4WD components from the production Lancer Evolution IX sports sedan, newly developed outer-rotor in-wheel motors were mounted on all four wheels. Fitted under the floor between the front and rear wheels in the space vacated by the 4WD components, a lithium-ion battery system powers the motors.
The new in-wheel motor was developed by incorporating Mitsubishi Motors’ vehicle installation technology to the motor manufactured by Toyo Denki Seizo K.K. The motor produces a maximum output of 50kW and its distinguishing feature is its outer-rotor construction. In the conventional type of in-wheel motor, as used on the Colt EV, the rotor turns inside the stator. The outer-rotor in-wheel motor, however, uses a hollow doughnut construction that locates the rotor outside the stator. The major benefits of this arrangement are as follows:
The design makes raising power output and torque easier and makes the speed reducer unnecessary, which reduces energy losses and restrains the increase of unsprung weight.
Elimination of the speed reducer makes the motor easier to fit into wheel house.
The doughnut construction creates space in center of the motor for the brake assembly and other components.
The outer-rotor construction also allows the motor to be mounted on the front wheels, something not possible until now because of the presence of steering system components. This evolutionary feature has opened the door to the realization of 4WD in-wheel motor vehicles and widened the potential for EV’s.
One of the Company’s major objectives in developing Lancer Evolution MIEV is to evaluate the outer-rotor type in-wheel motor construction, key to 4WD in-wheel motor vehicles, under an extensive range of driving conditions. To this end, Mitsubishi Motors has acquired vehicle type certification for Lancer Evolution MIEV to allow evaluation not only in the proving ground but also under normal driving conditions on public roads. These evaluations are designed to verify the reliability and durability of the outer-rotor in-wheel motor when subject to road surface inputs, to water inundation, and to exposure to sand and dirt - the major challenges this type of motor must overcome. The test program will also allow the Company to carry out research and development aimed at raising performance and at reducing weight and size.
Leveraging its trademark all-wheel control technology and know-how, Mitsubishi Motors is also considering developing a system that controls drive torque and braking force independently at each wheel and is eying its use in Lancer Evolution MIEV. The Company will aim for the realization of high-performance electric, hybrid and fuel cell vehicles that deliver not only superior environmental performance but also output performance and maneuverability equal to or better than gasoline-fueled vehicles.
http://www.speedsportlife.com/mitsub...motor/#more-69
Old Aug 25, 2005 | 09:42 AM
JGordon's Avatar
JGordon
Those diagrams make it look like it will have a really low center of gravity, always a good thing for a performance vehicle. Lotsa luggage space too. I wonder what kind of performance numbers that thing would put down? Depending on curb weight and range, this might be the first step toward a practical electric vehicle. Seems like the ride might be a bit harsh, however, what with all that weight in the wheels.
Now we just need to reinvest in nuclear power so that we can provide electric vehicles with a "relatively" clean & cheap way of recharging, rather than just shifting where in the power generation process we utilize fossil fuels.
Old Aug 25, 2005 | 05:11 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
i would not want to work on that car, one bad move and u could have a little shock from those stators
Old Aug 26, 2005 | 12:48 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
That is very cool.
Imagine a diesel-electric variant. You could take a 900cc turbodiesel triple to act as the generator, run it through the power cells and out to the wheel motors.
Keep the weight reasonable and the car would have some serious go.
Old Aug 26, 2005 | 02:19 PM
DakarM's Avatar
DakarM
Originally Posted by TheOtherDave™
That is very cool.
turbine engines are more effecient for that role... but both ideas aren't new
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old Aug 27, 2005 | 01:59 PM
TheOtherDave™
Apathy Kills
Very true. :yes:
I deliberately limited myself to the motors that MMC has available right now. If the car turned 0-60 in the high 6s or low 7s, while getting 45 mpg, I'd be all over it.
Old Sep 1, 2005 | 07:27 PM
Techme06's Avatar
Techme06
Eg b20b turbo
wouldn't the turbo heat up teh eletric generator making it less effecient ? sence this would only work for hybirds there will be two generator . the motor and the eletric genearato with turbo lag . wouldn't this give uneven power flow? i'm new with this idea
Old Sep 2, 2005 | 10:21 AM
Kestrel's Avatar
Kestrel
Push to shock!
He means a turbine based engine, like a jet engine.
Edit: I just read the rest of your post. Basically, diesel locomotives operate in this mode, it's called a serial hybrid. Basically, the reason engines are relatively inefficient is the large range of power they need to cover, anywhere from ~20 HP for highway cruising to > 100 HP for acceleration, and they are the most efficient at WOT (least pumping and pressure losses). The idea is that the engine is always running at its most efficient point, so you only really have turbolag issues during startup. The engine then charges the batteries pretty much at a constant rate.
The only downsides I see are a) it's loud as hell having an engine running WOT inside a car and b) lotsa batteries, with potential for shorts, undervoltages, and battery fires in an accident.
