Minivan, SUV, & Truck RDX, Ridgeline, Element, Pilot, MDX, CRV, Passport, Odyssey, and SLX.
94 honda passport 4x4 EX
Old Jan 27, 2007 | 05:17 PM
perbob29's Avatar
perbob29
Default 94 honda passport 4x4 EX
I just bought a 94 passportand can't figure out what is going on . The truck won't shift gears. Goes into reverse and first but nothing else. Also the brake and rear antilock lights stay on. I check the brakes out and they are in good shape and shouldn't cause the problem. I replaced the battery with a new battery. And don't know if trigered somthing or not. I would appreciate any help on this Thanks
Old Feb 1, 2007 | 03:52 PM
asheylarry's Avatar
asheylarry
well....you bought and izuzu rodeo with a honda badge on it, so that might be your main problem. if it grinds when you put it in revers then you need a new clutch, or you have a hydrolic problem. if you are low on brake fluid it will set both lights. you can take it to a shop and have them pull the abs code, but if the brakes stop you when you need them its not too big of a problem
