Odyssey engine surging
From what I've heard, even if you drill out the EGR ports on a J30A1 and do the "fix" the problem still reoccurs. So it's worth a shot, especially since it costs nothing to check/clean.
My 2002 Odyssey (57,000 miles) just started engine speed surging while at a stop. The check engine light came on as well. I noticed that it was less pronounced after the engine was warmed-up. Not sure if this is a problem with the EGR valve or something else (Idle control valve?). Has anyone else had this problem?
Thanks
Thanks
Thanks
Thanks
Found out that the cause of my particular problem of the engine surging with the check engine light on was a faulty/clogged Idle Air Control Valve. The diagnostic code was P0505 (per the dealer). They replaced it and all is good.
