Minivan, SUV, & Truck RDX, Ridgeline, Element, Pilot, MDX, CRV, Passport, Odyssey, and SLX.
Computer Guy Hacking a 2004 MDX
Old Nov 28, 2004 | 10:57 AM
vicorly's Avatar
vicorly
I'm going to have a custom car audio shop design a new bezel and make it all look professional.
Vic
Originally Posted by DRfrank
that monitor is a nice choice, i'd go with it, but it still looks a little off for a car. I'd try to find one that is square and that screws directly to the dash
Old Nov 29, 2004 | 11:46 AM
lgbr's Avatar
lgbr
Wal-Mart Shopper
If you can, find a DC-DC power supply, and avoid inverters. Converting DC to AC and then back to DC is about 70% efficient each time. A DC to DC (regulated) conversion can be 90% efficient. Inverters also create noise, bad idea. If you need to, you can take an ATX DC-DC power supply and hack the wires to match your Cube's wiring configuration.
Old Nov 29, 2004 | 12:10 PM
vicorly's Avatar
vicorly
Well, the G4 Cube has its own custom external power supply. The power supply (on the left in this picture: http://victor.orly.com/mdx-cube/Cube-PS.jpg ) supplies the Cube itself with 28 vdc. Why 28v? Because the Cube has the proprietary video card connector, ADC (Apple Display Connector) for plugging in the now discontinued older Apple flat screen displays and supplying power, video signal and USB over the same cable. The video cards don't have to use that, they also have a VGA connector (some other cards have ADC and DVI). Internally, other components are 12, 5 and 3.3 volts, stepped down by the internal DC-DC Board (voltage regulator module, http://victor.orly.com/mdx-cube/Cube-DC-DC-Board.jpg )
Personally I don't need the 28 vdc since I'll likely use the VGA output. I may rig up a way to supply just 12 volts to the computer, if the DC-DC module allows that. Otherwise I'll have to use the inverter.
Victor
