1st -> 2nd grind...
Old Jan 20, 2003 | 05:53 PM
ShaolinLueb's Avatar
ShaolinLueb
Originally posted by Kaiz
I think it might be cause the clutch isn't disengauging all the way. I'm not sure how to fix this besides gettin a new clutch/pressure plate?
:werd: get the leak fixed and adjust your peddle a little bit, that will put some more pressure on it. my clutch jut got replaced and i had 81k on it. oh if you do master cylinder do slave also at the same time.
i have heard, don't know if its true, that integra's have a weak 1st and 2nd??? don't know anything about that,
Old Jan 20, 2003 | 06:57 PM
Weston's Avatar
Weston
Try replacing and properly bleeding the clutch fluid... I replaced the clutch master cylinder and the problem didn't go away, but I don't remember having a problem once I eventually bled it *properly*. I think having a short shifter at the time amplified the problem, but wasn't the cause of it.
It still does it now, but *only* if I'm lazy on the clutch (ie don't press it far enough or fast enough; totally my fault).
Old Jan 20, 2003 | 08:33 PM
Kaiz's Avatar
Kaiz
See that's what's different between our cars now. Mine grinds only when the clutch is ALL the way down touching the floor...and it only does it on fast shifts in the higher rpm range. It's like the syncro can't keep up with my shifting...But how can that be? The car is less than 2 years old.
Old Jan 21, 2003 | 07:20 AM
ShaolinLueb
i dont want to sound like a bastard, try to find someone at acura who knows what they're talking about. i once dealt with a guy who didn't know what a short shifter was :rofl: and ask them whats up with the trannies in tegs, then come back and report to us.
Old Jan 21, 2003 | 09:17 AM
BonzoAPD's Avatar
BonzoAPD
yeah some people at acura dealerships don't know much at all
Old Jan 22, 2003 | 04:56 AM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
When my car is outside (its cold in pittsburgh now). There is a slight notchieness(sp?) when shifting from 1st to 2nd. But when the car warms up it goes away
Old Jan 22, 2003 | 06:42 AM
ShaolinLueb
yeah it has notched when its cold cause the liquid isn't flowing that well since its cold. when it warms up it sticks better and goes away. let your car warm up for five minutes or so. i get the same thing, i let my car warm up for 5 minutes and it goes away.
NOSon
10
Dec 8, 2003 11:23 PM
TypeRCivicEG6
92+ Civic/EL & Del Sol
5
Jun 1, 2003 09:03 PM
jaxrunner
May 18, 2003 11:42 AM
rvfrick
3
May 9, 2003 12:53 PM
jordan88
7
Jan 27, 2003 07:22 PM
