ECU's influence on charging system?
Old Sep 8, 2003 | 09:12 AM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
Default ECU's influence on charging system?
hey everyone, i've been having some trouble with my swap because 1.) can't get my car started, 2.) when i push start my car, the alternator seems like it's not working (reading only 12.8 V+ instead of 13-15 V+) :sad:
i've replaced the starter, and altenator, and recharged the battery already and still the same problem. i'm hoping that if i can get the charging system to run correctly, the battery will get the extra needed boost to start my car. h:
here's my question:
how much influence does the ECU or ELD (electronic load detector) have on the starter and/or charging system? when the car starts, does the ECU send out a signal to regulate the voltage or does the ELD do that? i'm thinking that everytime i start my car, the ECU is either receiving or sending out a false signal to the altenator causing it to not generate the expected output voltage. any insights will be appreciated. :bigok:
