help with engine light
Old Sep 8, 2003 | 06:03 AM
Ice025's Avatar
Ice025
Default help with engine light
i used a paperclip to see what code my car is throwing that was making my check engine light come on. it gave me a code 54 which is ckf sensor (crankshaft speed fluctuation) defective circuit or unplugged/defective sensor. anyone know how to fix this problem, or where this sensor is located. i'd rather try to do it myself than take it to a shop if its possible. thanks in advance for any help you may be able to give me.
Old Sep 8, 2003 | 09:12 AM
JimBlake's Avatar
JimBlake
Isn't that one down by the crank pulley? So the level of difficulty is kinda like changing the timing belt.
Old Sep 8, 2003 | 09:16 AM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
how many miles are on your car and what modifications have you done? it's on a VERY RARE occasion that this sensor goes bad. it could be possible that the plug has come loose. this was the same code i got a couple days back on my motor and the plug was disconnected.
btw, this is the sensor located on the bottom of your block right by the timing belt.
