squeaky clutch???
Old Sep 18, 2003 | 07:19 AM
JimBlake's Avatar
JimBlake
It doesn't have to be the actual throw-out bearing spinning that makes the noise. When you work the clutch (even with the engine turned off) the T-O bearing slides in & out on a tube surrounding the input shaft. That tube might need some grease, or maybe it's the pivot of the T-O fork that needs grease.
It can also be the master or slave cylinders, but I think that would sound different?
Old Sep 18, 2003 | 12:50 PM
99GSRbeerman's Avatar
99GSRbeerman
There is a speed limit?
so what do i do...if lube how do i get to it?
Old Sep 19, 2003 | 06:48 AM
JimBlake's Avatar
JimBlake
Some possibilities are bad news...
1) The piston rod in the slave cylinder. Open the rubber boot at the slave, & open the smaller accordion-type boot on the piston rod. Grease inside there.
2) Ball & socket end of that rod. The outer end of that piston rod is a ball that sits in a socket on the throw-out fork. Grease that.
3) Ball/Pivot of the shift fork. That's a short distance inside the bellhousing. It's kinda hard to get to, maybe get some grease on a long slender tool of some kind. I wouldn't spray grease all over in there, because you don't want to grease up your clutch plate.
4) Sliding surfaces of the throw-out bearing itself. That's the tube I'm talking about above. I don't think you can get to this without removing the transmission...
Old Sep 21, 2003 | 05:34 PM
Shore 96 Teg's Avatar
Shore 96 Teg
I miss my 93 VTEC Lude :(
What he said = too much damn work for a squeak. Turn up your radio h:
Old Sep 22, 2003 | 05:47 AM
99GSRbeerman
what happens if i leave it?
Old Sep 22, 2003 | 09:16 AM
JimBlake's Avatar
JimBlake
If you leave it I hope it'll keep squeaking for a really long time before it does any real damage to itself.
I've greased the stuff I can reach without removing the transmission. That's #1, 2, & sorta #3. That made it better, but not completely gone. Now I'm waiting for my clutch to wear out; in the meantime I turn up the stereo...
Old Sep 22, 2003 | 03:02 PM
OregonHusker's Avatar
OregonHusker
Default Re: squeaky clutch???
Originally posted by 99GSRbeerman
i have a 99 gsr with 63k miles on it. from what i know i think its the orig clutch. when i push the clutch pedal in or out somthin squeaks. it dosnt matter if the car is on or off. it also dosnt do it all the time. god its so f-in anoying
what is it????????
A few years ago mine squeaked everytime I stepped on it. I sprayed some silicon spray on the cylinder and it hasn't squeaked since.
Old Sep 22, 2003 | 03:54 PM
XSrcing's Avatar
XSrcing
integra clutch master cylinders are notorious for leaking. and usually when they start leaking, they start squeeking. my last integra did it, and the one i have now does it. as does my friends.
