squeaky clutch???
i have a 99 gsr with 63k miles on it. from what i know i think its the orig clutch. when i push the clutch pedal in or out somthin squeaks. it dosnt matter if the car is on or off. it also dosnt do it all the time. god its so f-in anoying:mad:
what is it????????:confused: |
The throw-out bearing might be defective, thus it caused all the noise.
Mine used to do that constantly. I replaced my master cylinder and clutch at the same time and I had no problems after that. Clutch was quiet again.
Originally posted by GSuperR The throw-out bearing might be defective, thus it caused all the noise. |
it sounds like the cable is makin the noise? it dosnt sound like any parts of the car....then again i dont know a whole lot either
Originally posted by 99GSRbeerman it sounds like the cable is makin the noise? it dosnt sound like any parts of the car....then again i dont know a whole lot either |
I searched on Honda-Tech about this and the master cylinder may need some grease. Remove the rubber boot by the pedal and put some grease in there.
My pedal is doing the same thing, but it doesn't always do it. Can the throw out bearing still squeek when the car is off?
Originally posted by teg_fan My pedal is doing the same thing, but it doesn't always do it. Can the throw out bearing still squeek when the car is off? |
yah my car dosnt do it all the time either
