How are integras on gas??
Old Jul 10, 2002 | 08:42 AM
  #31
BonzoAPD's Avatar
BonzoAPD
How would a set of 17's on the car affect mileage? Do they make you put more miles on the car or less?
Old Jul 10, 2002 | 08:49 AM
  #32
95acurals's Avatar
95acurals
How do I change this?
21mpg my car is screwed up. I used to get 29mpg.
Old Jul 10, 2002 | 09:45 AM
  #33
Meguel24's Avatar
Meguel24
Platinum Plus Member
I dont know about my MPG (not gonna do the math) but I get on ave 300 miles on a tank, but this weekend i went to LA from San Jose on HWY5 and got 200 miles at half tank, with an additive. I really wanted to know if I'd get 400 off one tank, but coming up to the Grapevine mountain I had to refill, since I wont make it to the next gas station.
Old Jul 10, 2002 | 10:01 AM
  #34
99IntegraGS's Avatar
99IntegraGS
400 (miles) / 13.2 (gallon tank) = 30.3 mpg
It would take some nerve, but I think it's possible.
Old Jul 10, 2002 | 10:27 AM
  #35
Meguel24's Avatar
Meguel24
I should mention 94 RS automatic with many mods averaged 65-70 mph. And how certian are you on the tank size being 13.2, I always thought is was less since I never pump more than 11 gal at the pumps. U learn something new everyday. So then when does the fuel light come one? less than 1 gal or 2???
Old Jul 10, 2002 | 10:33 AM
  #36
99IntegraGS
I should mention 94 RS automatic with many mods averaged 65-70 mph. And how certian are you on the tank size being 13.2?
I'm not.
I looked at the pics of your car in the other thread you posted in and assumed it was a '99 or newer. I guess you have a new front end, since the pics didn't show the little divider in the opening below the front bumper.
I just checked Edmunds.com, they say your '94 holds 13.2 gallons.
Old Jul 10, 2002 | 10:41 AM
  #37
drdavidge's Avatar
drdavidge
so what are the causes of ****ty gas mileage?
Old Jul 10, 2002 | 10:50 AM
  #38
95GS-R's Avatar
95GS-R
Um What?
Rim size doesn't matter, you need to calculate overall tire diameter. It is possible to have 17 inch rims and a smaller overall tire diameter than stock, or larger, depending on what size tires you use.
Heavier rims will require more throttle for the same acceleration, so you could chew through more fuel that way.
Old Jul 10, 2002 | 11:33 AM
  #39
95acurals's Avatar
95acurals
tire pressure, tires balanced or not, alignment, mods, how you drive, bad gas. there are many things that cause bad gas mileage.
Old Jul 10, 2002 | 12:47 PM
  #40
juiceweazel's Avatar
juiceweazel
Mobfather of all
man this is one heck of a thread on just gas mileage! i took a trip to NY to visit my buddy & after 280 miles i filled up, only 7 gallons!
that equals 40mpg. this was before the stereo.
if your tire circumfrence is larger than you will put less miles on the car because the tire isn't rotating as fast, that also equals what seems to be less gas mileage. yes it's probably a little less, but nothing to be worried about.
