Regular or Synthetic Oil??
Old Jul 3, 2002 | 07:08 AM
StyleTEG's Avatar
StyleTEG
Make me an offer
Originally posted by 1funride
Driving any car hard will fvck it up no matter what oil you put in it..
And you know this for a fact? Have you seen or done tests that show that regardless of wear additivies and types of oil driving hard will "fvck up any car".
Synthetic oils have more wear protection, more wear protection means less wear especially under hard driving conditions.
For daily driven cars, the benifits are
Synthetic oils also work better at low temperatures because they flow much more freely down to -40 to -50 degrees F. Also, synthetic oils start lubricating much sooner and reach critical areas much faster.
The advantages? Longer intervals between oil changes are possible because synthetics suffer less breakdown due to the better base stock used. Usually the synthetics will have a better additive package, allowing the oil to clean better among other things.
Old Jul 3, 2002 | 07:15 AM
1funride's Avatar
1funride
99 Integra LS
Mabe I should have made myself more clear....What I meant by "driving a car hard" basically, abusing the car....And no I haven't done tests, but I have talked to other mechanics about this, and I have come to the conclusion that sythetic is not needed (imo).
Old Jul 3, 2002 | 07:28 AM
StyleTEG's Avatar
StyleTEG
Make me an offer
You are correct, a car that is beat on is a car that is beat one. Synthetic oils can reduce the damage that is done though.
There is a difference between a mechanic and an oil speciallist. Just because he can change parts on your car, doesn't mean he is an expert on oil.
Not everyone needs synthetic oil, sometimes dino is more than enough, sometimes a synthetic blend is enough. There are plenty of situations where synthetic oil is worth the added cost, even on small, daily driven engines like B18's.
Old Jul 3, 2002 | 07:33 AM
1funride's Avatar
1funride
99 Integra LS
Just curious...Are you an oil specialist? Chemist?
Old Jul 3, 2002 | 07:48 AM
StyleTEG's Avatar
StyleTEG
Make me an offer
Nope, I just have read more about oil that I ever really needed too
Old Jul 3, 2002 | 08:40 AM
integramodder's Avatar
integramodder
hey styleteg, where is that guy that is the oil chemist...we had like a 4 or 5 page discussion about this a while ago....
Old Jul 3, 2002 | 08:46 AM
StyleTEG's Avatar
StyleTEG
Make me an offer
Bror jace?
I see him on Honda-tech every once and awhile.. he had a good 11 page thread on oil going there on the TypeR Forum.
I also hear he is on the edmunds.com forums as well, and he is on Bobtheoilguy's forums as well http://theoildrop.server101.com/cgi/ultimatebb.cgi.
Kinda wish I had saved that thread before the crash, it had lots of good information on it.
Old Jul 3, 2002 | 09:59 AM
rabican's Avatar
rabican
...yes honda does say to use synthetic oil look in the manual...
Old Jul 3, 2002 | 10:28 AM
jgrotkier's Avatar
jgrotkier
AIM SN: Johann14420
Originally posted by integramodder
For those who say synthetic isnt worth it. Consider the fact that an integra's oil change is suppose to come every 7,500 miles, not like someone said at 3,000. With the use of synthetic, you should change it every 15,000. This way its cheapper, and its just as good. When I use synthetic, I still change it every 7,500 since I drive hard often enough.
you on crack?
Old Jul 3, 2002 | 10:31 AM
1funride's Avatar
1funride
99 Integra LS
acually the manual says you may use synthetic motor oil if it meets the same requirements given for conventional motor oil (per my manual for 99 integra, page 169.)
