tranny problems help
I have a 90 integra with the stock b18a1 and i have a problem my tranny was working fine and i moved my car to another spot on my drive way and an hour later i was on my way out i started my car up and found that the gears dont work any more i thnk it is the clutch because i can kinda hear some rubbing in the tranny and the speedometer is registering some sort of speed when i let the clutch out is there a way to adjust my clutch or something or do i have replace it what do you guys think any help would be greatly appreciated
This sounds like the same thing that is happening to my car, I just swapped a type R engine into my 95 civic. Got it all put in and started just fine, reversed out of the shop, when I went to put it into first, nothing. Now I can shift through all the gears without the clutch in and it never grabs, I just replaced the clutch, pressure plate and throw out bearing. Still nothing. Also as I shift the speedo changes, the higher the gear the higher the speedo sits, 5th gear, around 20 mph. also when I rev it the speedo goes up also
i dont know for jay....but dcsmith sounds like the half shaft isnt all the way in? it wouldnt explain the reverse situation but if your half shaft isnt all the way in the car wouldnt move nor grind etc.... it just wouldnt move when clutch out.
89crxinprogress
CRX & Pre 92 Civic
8
Aug 27, 2004 11:16 PM
swtchink13oi4u
8
Jan 8, 2003 05:56 AM
