spoon ecu
Originally posted by SaM i M
i need to buy ecu cuz am runing ls vtec now with the ls ecu so in conclusion i need an ecu
thats why i ask bout those ecus
i got a 94 gsr ecu now
You asked about the Spoon ECU and I'm telling you it's a waste of money. You will produce more power with any of the options I listed below, and most of them are probably CHEAPER than buying a product that's overly hyped and rather ill-fitted for your particular application.
So INSTEAD of getting the "Spoon all-purpose-ECU-that-isn't-tuned-for-your-particular-application", have your ECU custom chipped (as I stated earlier above), or better yet, get yourself a V-AFC or hondata and save up for some dyno time. This way you can always "re-tune" your ECU for whatever new mods you put on.
Shingo
Oh, and FYI, the Spoon ECU is $1500
http://www.modacar.com/products/Acura/Integra/MODAECT/
A hondata 3B (you can probably do fine with the cheaper 2B) is $469.
An Apexi V-AFC is $340.
Dyno time runs anywhere from $100->$200/hr. Depending on the application, 1.5->2hrs should be more than enough time.
Shingo
Shingo
Shingo
Shingo
the reason i asked bout the spoon ecu was cuz somebody tryin to sell me one and telling me its the real shit and i wasnt convinced, but i just bought a gsr ecu chiped for 200$
i will be getting the apex v afc soon and i can dyno and tune my car at skool my self so that aint a problem
and bout spellin shit correctly on da boards is sum i dunn give a **** bout
You can also use an A/F gauge + G-tech to do some on-the-fly-ghetto tuning on an empty street. There are probably a few people around here who can give you "acceptable" settings for the V-AFC right off the bat.
Shingo
Or you could pick up a cheap wideband.
So is the GSR ECU you bought Spoon chipped? If so I'd buy a cheap chip with modified vtec settings and revlimit and throw that trash away.
It's not for street use, runs pig rich, destroys your gas mileage, and disables the check engine light in almost all situations. The ECU was designed to keep going no matter what... if something goes seriously wrong with your motor, it could be trashed before the ECU lets you know you just destroyed your engine.
