Revving past 8k.......
Old Apr 1, 2003 | 10:48 AM
ur31337's Avatar
ur31337
Colby
Well, the ITR motor wouldn't be a bad deal if you don't want the hassle of building a C1 up. Although, if you're dedicated, building up is the way to go.
Old Apr 1, 2003 | 11:15 AM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
Originally posted by eclipse spanker
COOL !! Im actually contemplating getting a type r motor, instead of blowing money on all types of shady bolt-ons. I'll be there also casue my parents live in East Hartford, and I'll be visiting them that weekend.
Don't you have a GSR? There are plenty of reliable go-fast parts; no need to waste a perfectly good B18C1.
The ITR is also lighter, and stock for stock has a better suspension/frame + transmission, so just the engine alone won't do much.
Shingo
Old Apr 1, 2003 | 11:53 AM
eclipse spanker's Avatar
eclipse spanker
Good point.......but I mean will my gsr motor be just as reliable/powerful as a b18c5, if I bolt on a few thousand dolars worth of parts ? Also, do any of you guys know what the difference is between stock quarter mile times ?
DB7 2.0's Avatar
DB7 2.0
Banned
Default Re: Revving past 8k.......
Everyone is always talking about putting in titanium valves springs and retainers so that they can rev up to like 9 or 10k, but what is the point of revving that high, if the gs-r still makes max power at 7600 ?
if those people are on stock cams then theyre idiots
Old Apr 1, 2003 | 11:59 AM
ur31337's Avatar
ur31337
Colby
If you go to www.itr1220.com like I said, they comapre the two cars at the same time.
Stock times for any car, much less two different cars, won't mean a thing. I've seen a stock ITR ring up a 14.2 1/4 mi, but I've seen a 14.9 also. I've seen 6.2 to 6.8 0-60 times, that also doesn't mean too much.
SCC compared the 4 cars under the same conditions, so it's as close as you're going to get man. Just trust us when we say 25 hp & 100lbs makes a big difference. Not to mention gearing & MUCH stickier rubber on the R.
Old Apr 1, 2003 | 01:19 PM
Shingoblade-GSR
Hellsing Agency
Yes, it can be just as reliable, although like I said before, you shouldn't be so preoccupied with just the 25 hp gap; the ITR has many performance advantages over the GSR that are unrelated to its power output.
Note that if you decide to swap out the engine and do a poor job, you'll run into a host of reliability issues as well.
Shingo
