jack placement
Old Feb 17, 2003 | 08:30 PM
homer's Avatar
homer
Default jack placement
I know this was discussed a few weeks ago, and I did a search, but I couldn't find a satisfactory answer as to the exact place to put the jack when I wanna jack up the entire front end. I saw the "arrow" on the underside of the front air dam, and was wondering- do you put the jack directly on that plastic arrow, or to where it points? The chilton's manual has a picture, but it's pretty blurry and grainy.
thanks, homer
Old Feb 17, 2003 | 08:35 PM
airon's Avatar
airon
AARONNOJIMA.COM
it shouldnt be a plastice piece but part of hte frame
right underneath a little to the tranny side is the arrow and correct jack placement
Old Feb 17, 2003 | 08:53 PM
homer's Avatar
homer
Thank's for the quick response, mr. airon
homer
Old Feb 17, 2003 | 09:06 PM
Quick Silver's Avatar
Quick Silver
Vroom Vroom..!
anyone has pics of this ?
I've looked for the spot but can figure out where it is at
Old Feb 18, 2003 | 05:10 PM
newgsrdriver's Avatar
newgsrdriver
If you still have your splashguard...theres a cutout for it. Its just a "bump", and the plastic is actually cut out to accomodate it.
Old Feb 18, 2003 | 06:13 PM
tilt's Avatar
tilt
I've tried jacking on the front portion and the jack never gets the car high enough to get the jackstands to clear. Same with jacking the rear tow hook . I end up using a block of mdf and jacking on the body, which prolly isnt the best thing to do. Anyone have a solution to this?
Old Feb 18, 2003 | 06:46 PM
airon's Avatar
airon
AARONNOJIMA.COM
what kind of jack are you using?
and how low is your car?
even with the stock jack under the front jack point, and on some 4" high blocks, i could fit jackstands
now i use my craftsman jack and can hella fit underneath
Old Feb 18, 2003 | 10:06 PM
tilt's Avatar
tilt
I'm dropped ~1.3" on pro-kits. I bought my 2ton jackstands and jack from autozone. Maybe i need a bigger jack?
Old Feb 18, 2003 | 10:36 PM
airon's Avatar
airon
AARONNOJIMA.COM
i got a 3 ton jack
depends on high high it goes though
mines
http://www.sears.com/sr/product/summ...id=00950139000
it goes up 19-3/4 inches
Old Feb 19, 2003 | 12:25 AM
DB7 2.0's Avatar
DB7 2.0
Banned
on a standard run of the mill jack from pepboys/autozone and the like, the middle jack point isnt enough to raise up the front end for jackstands, unless the very lowest setting is fine. mine was a pain the ass, but i had to jack up the front end up from the front tow hook, then jack up the side from the side rear jackpoint, only then i was able to slide the jackstand at the desired height under the side front jackpoint.
