MAP Sensor ?????
Old Feb 12, 2003 | 08:41 AM
paymepunk's Avatar
paymepunk
Default MAP Sensor ?????
Hey i looked up some trouble shooting codes for my '88 teg and it is flashing the MAP sensor code.....could anyone tell me waht this is and what i might need to look at thanx
Paymepunk
AIM= Paymepunk
Old Feb 12, 2003 | 09:29 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
MAP = manifold absolute pressure
This is the sensor the ECU uses to determine how much air is going into the motor. It uses the voltage off the MAP sensor and the RPM to determine how much fuel to inject.
As for what's causing the code, *generally* unless you have something unplugged it's time to replace the sensor.
