clutch
hey guys g1 teg .. any simple ways on adjusting the clutch.? i def know that it is time for a new clutch.. wut u guys think? and is it hard to change the clutch? how much is labor usually so i dont get ripped thanks guys
it'll cost ya around $500 if a shop installs and charges you for the new clutch.
or you can buy an ACT clutch for $250 and install it yourself, this is what i'd suggest you do...that is if you know how to install a clutch.
You can adjust the clutch cable at both the pedal, and at the transmission. If you go to a good Honda/Acura shop then they should be able to adjust the pedal for you which will help with the feel.
