GS motor swap
Old Apr 25, 2009 | 08:02 PM
Soupytuna's Avatar
Soupytuna
Default GS motor swap
i have a 99 integra gs i can take a jdm b18c motor and put that in correct without any problems? i heard all B motors would fit
Old Apr 26, 2009 | 06:05 AM
jrgoswick's Avatar
jrgoswick
Some old guy!
Gotta do a P72 head and ECU for a TRUE GSR. Mounts will work.
Old Apr 26, 2009 | 07:22 PM
Spec R's Avatar
Spec R
you'll have to wire up the vtec solenoid and intake manifold butterflies (if its non-ITR).
jdm B18C's with serials that start with 19, 20, 21, and 22 are ITR blocks.
there is no suffix after the "C" in B18C unless its a US motor or a factory rebuild block.
DB Squad
Integra Forum Moderator
Old Apr 26, 2009 | 09:29 PM
Khazzy's Avatar
Khazzy
The know nothing kid.
im assuming he has the head if he is doing the engine swap, the ecu i understand though, this is good info because i plan on doing this very same thing next year
Old Apr 27, 2009 | 12:01 PM
jrgoswick's Avatar
jrgoswick
Some old guy!
Also forgot the oil squirters in the block. These shoot oil onto the bottom of the pistons for cooling.
The reason for the ECU is for the vacuum control valve control for the secondary runners in the plenum.
Old Apr 27, 2009 | 12:16 PM
Khazzy's Avatar
Khazzy
oh i know for the ecu lol was just saying if he is doing a swap id assume he has the entire block
Old Apr 27, 2009 | 12:26 PM
jrgoswick's Avatar
jrgoswick
Some old guy!
Gotcha. BUT you can also put the P72 on any B block. I wonder if you can also implement the squirters into a B20 for a BIG hybrid?
Old Apr 27, 2009 | 04:13 PM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
You can use any ECU. If it's not a VTEC ECU, you'll have to get it converted to a VTEC unit, and have it chipped with a stock map, or even a tune.
The mounts are the same. Use stock GS-R mounts or even aftermarket like Avid, Hasport, etc.
The LS and B20 are the same engine, just different slized sleeves, so yes, you can use the squirters.
Old Apr 27, 2009 | 07:27 PM
jrgoswick's Avatar
jrgoswick
Some old guy!
Don't you have to drill/tap the block for it? Otherwise wouldn't there be a drastic oil pressure drop? I thought the LS was an interior options package upgrade, didn't think it applied to powertrain. I COULD BE WRONG!
Old Apr 27, 2009 | 09:10 PM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
Using the B18a/b with a VTEC head is the same thing as using a B20b/z with a VTEC head.
I meant LS meaning a B18a1 or B18b1. Since all Integras came with those engines besides the Hype R and GS-R
