Underbody paint (subframe)...
Old Mar 2, 2009 | 12:23 PM
A-dub5513's Avatar
A-dub5513
Default Underbody paint (subframe)...
Hey guys,
I've finally found a welder and getting around to having my subframe tearout repaired. He'll reweld/patch the split seams around the sway bar mount points, then grind/smooth out the surface. But before mounting the ASR brace and sway bar, I'd like to have that area painted (to avoid rust) but wanted to know if anyone has any suggestions on the type of paint to use (rust prevention, paint durability, color match, etc.).
It'd be awesome if someone knows where I can get the paint Honda uses.
Thanks,
A-dub
Old Mar 2, 2009 | 08:08 PM
Lynxs1981's Avatar
Lynxs1981
Unless you're showing, just get some of the spray undercoating from the local parts store. Best for rust prevention.
Old Mar 4, 2009 | 09:35 PM
thetunersource's Avatar
thetunersource
With the underbody , you should definitely spray it so that it doesn't rust any further.
Old Mar 5, 2009 | 06:27 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Yes and Yes
Old Mar 5, 2009 | 01:25 PM
A-dub5513's Avatar
A-dub5513
Understood, but any brand I should be looking for (Rustoleum, etc.)? I know it seems like the question has been answered, but I don't want to end up with low quality paint that'll start chipping/flaking off after.
Thanks, guys.
Old Mar 5, 2009 | 02:03 PM
Lynxs1981's Avatar
Lynxs1981
If you're looking at paint, Krylon is always good. As for spray on undercoating, the manufacturer is not that important.
Old Mar 5, 2009 | 02:14 PM
Line7's Avatar
Line7
Platinum Member
I used BBQ grill paint for my exhaust. Goes on black, resists high heat, and rust.
Old Mar 5, 2009 | 03:26 PM
Spec R's Avatar
Spec R
i think that a company called SEM makes a specific underbody spray. its popular with the prosumer crowd.
post pics of the tear out - its rarely photographed.
DB Squad
Integra Forum Moderator
Old Mar 5, 2009 | 07:07 PM
A-dub5513's Avatar
A-dub5513
Thanks, I'll check into that.
Ask and you shall receive...
File Type: jpg
File Type: jpg
Old Mar 5, 2009 | 10:27 PM
Spec R's Avatar
Spec R
holy crud that looks vicious. sorry to hear
DB Squad
