Integra Electric Condenser Fan stays on
Old Mar 1, 2009 | 12:31 PM
martinjsxx's Avatar
martinjsxx
Default Integra Electric Condenser Fan stays on
I have a 91 Integra GS, problem is the electric condenser fan comes on when I shut the engine off. It stays on until the battery is dead, though sometimes I can get it to shut off if I turn the engine on and off again. It was such a problem that I have taken the a/c fuse out to avoid a dead battery.
I have taken it to 2 different garages. They have separately replaced 2 different relays but the problem persists. Any guidance would be much appreciated.
Old Mar 2, 2009 | 04:19 AM
phatintegra's Avatar
phatintegra
Change your thrmostat.
Old Mar 2, 2009 | 06:13 AM
martinjsxx's Avatar
martinjsxx
Default Electric Condenser Fan - Thermostat question
Thank you so much for replying. Am I correct in understanding that this is the main cooling system thermostat? (The car never overheats and the electric fan doesn't operate with the engine on, but comes on when it is turned off.)
Old Mar 2, 2009 | 08:04 AM
Lynxs1981's Avatar
Lynxs1981
Either they haven't changed the right relay, or you have a short somewhere keeping the relay closed and the fan running.
Old Mar 2, 2009 | 08:30 AM
martinjsxx's Avatar
martinjsxx
The second mechanic said the first one screwed up and changed the wrong relay and missed a short circuit in the climate control system. He was positive he fixed it but a day later, same problem!
Old Mar 2, 2009 | 09:52 AM
phatintegra
Cooling thromostat is stuck open so that's why the temp gauge never got hot, but your fan will stay on. I had the same problem in my old vehicle.
Old Mar 2, 2009 | 08:07 PM
Lynxs1981's Avatar
Lynxs1981
2 fans, correct? So when you're standing in front of the car, the one on the left is coming on?
Old Mar 2, 2009 | 08:08 PM
cruzalekz's Avatar
cruzalekz
why dont you just unplug that fan since you dont need it.
Old Mar 3, 2009 | 12:13 AM
martinjsxx's Avatar
martinjsxx
Yes there are 2 fans. Standing in front of the car, it is the one on the right that comes on.
This fan is not needed? How is it unplugged? Wouldn't it overheat with the A/C on?
Old Mar 3, 2009 | 07:12 AM
phatintegra
There is 1 fan for the A/C and the other fan is for the motor. The one for the A/C I would not disconnect it if your radiator been upgraded to the Alluminum core. If you disconnect the A/C fan your A/C won't get cold like before. Something to think about.
EDIT:
I had a chance to look at pics of my set up. The fan on the right is your A/C if your facing the vehicle looking toward the firewall.
