Crisis In MIDLIFE!!!
Old Dec 13, 2002 | 04:45 AM
98RedGS's Avatar
98RedGS
Default Crisis In MIDLIFE!!!
im caught up in a problem i want your opinioon please!
I got the option to fix up my eclipse or my integra GSR.
Now im thinking this because its an option but i want an opionion from you guys.
#1 - which would you think would be faster in the end?
#2 - which one you think would look better?
#3 - which one you think could get into the 13/ low 12's for less?
#4 - which one would you do what to?
#5 - Gimme a why to number 5....
i was thinking just go looks with the eclipse with normal bolt-on's but i want your opinion on this subject...
HELP ME!!!!!!!!
Old Dec 13, 2002 | 05:23 AM
kfar09's Avatar
kfar09
what model eclipse?
Old Dec 13, 2002 | 05:33 AM
JGordon's Avatar
JGordon
If you have an Eclipse GS-T or GSX, it will easily be faster than your teg, but not as reliable (depending on condition.) You can put down good numbers with a turbo Eclipse for pretty cheap.
If you've just got a base model Eclipse, mod your GSR. However, It will cost a lot to get the GSR into the 12's. I think the GSR looks a little better overall, but Eclipses can look very aggressive with a nice drop and good wheels.
Old Dec 13, 2002 | 07:35 AM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
If it's an eclipse GS-T or GSX, in terms of straight-line speed, it will eat a similarly modded integra for breakfast. All day, every day.
The integra does handle considerably better than the eclipse, so it depends what you want.
Shingo
Old Dec 13, 2002 | 10:02 AM
b00gers's Avatar
b00gers
yea...depends on the model eclipes.....if its a nonturbo...then blah, go for the GSR.
#1 - depends on the model eclipes, if its turbo, then that. otherwise gsr
#2 - gsr
#3 - see #1
#4 - gsr
#5 - gsr fan.
Old Dec 13, 2002 | 11:52 AM
B18C1TEG's Avatar
B18C1TEG
not really. Drag III kit @ 9psi (at the track) good tires/ driving skills and tuning and its very possible.
Old Dec 13, 2002 | 12:51 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Good tires in that case, being drag radials at the miniumum.
Old Dec 13, 2002 | 01:05 PM
Shingoblade-GSR
Hellsing Agency
If you dump the amount for a Drag Gen III + tuning into an Eclipse GS-T/GSX, you would most likely be able to smoke the aforementioned gsr. Does that answer question 1?
Looks are subjective. Do whatever you think looks best, because regardless if you go with the "JDM" look or with the "streetz tunerz battle-R" look, you'll still fail to please even half the fools out there.
Shingo
Old Dec 13, 2002 | 01:19 PM
98RedGS's Avatar
98RedGS
How much is the DRAG GEN III kit?
In cause i forgot to post this (which i did) its an ECLIPSE GS.
How much cash do you think it would run to get the integra into the 13's???
Old Dec 13, 2002 | 01:25 PM
Shingoblade-GSR
Hellsing Agency
In that case go with the gsr.
As to how much cash, there's the forced induction route and the all-motor route. The F/I route is cheaper. 13's should be very possible with a Greddy running 6 psi, tuning, and some drag radials. If I had gone that route, it would have cost me $4,000. I'm sure you can do it for cheaper as there are some "shortcuts" you can take.
Shingo
