Nitrous/Alcohol ??
Old Nov 27, 2002 | 11:52 AM
eclipse spanker's Avatar
eclipse spanker
Default Nitrous/Alcohol ??
I was thinking about this concept, all though I'm sure many people have already done it. My buddy has a maxima that has close to 400 flywheel hp, and one of the things that he uses is a special setup that sprays fine mist alcohol directly into the intake manifold to cool the air down really fast (as you guys know, colder air= more dense air).......At first I was thinking that it would be complicated to set this up...but then it hit me....why not just use a direct port nitrous setup, and replace the nitrous with alcohol ? This way have a system that increases your performance considerably, but at the same time, isn't as potentially harmful to your engine as nitrous . Have you guys ever heard of anyone doing this before ? Do you guys think that this would work ? What kind of hp gains do you think it would create ?
Old Nov 27, 2002 | 02:27 PM
kris79's Avatar
kris79
Owner of CEmotorsports
its called water injection, mainly to prevent detonation, i have an aquamist kit. it lets me put my timing back to stock instead of retarding it.
Old Nov 28, 2002 | 12:28 PM
justinls's Avatar
justinls
i would not recomend it eclipsespanker. my buddy has a cavalier and we rigged it up with the alcohol and it worked at first, but then about a month later he blew his motor(chevy sucks). Maybe we set it up wrong but it was the same concept you are talking about. PLEASE dont kill a kick butt gsr think about what your about to do. Remember its a integra not a civic keep it clean
Old Nov 28, 2002 | 07:58 PM
95TEGyoure it's Avatar
95TEGyoure it
Billy Sexcrime
potentially harmful because it can puddle up in the intake manifold....thats my guess
Old Nov 29, 2002 | 08:23 AM
bucash's Avatar
bucash
Go ahead and try it then let me know
Old Nov 29, 2002 | 10:17 AM
eclipse spanker
The thing is though, that it would be sprayed as a very fine mist, so I think it would have less of a chance of puddling up. FatBooty, whats your take on this ?
Old Nov 29, 2002 | 04:27 PM
Deagle's Avatar
Deagle
Nüb
Ethanol alcohol is a common additive in gasoline. I'm not 100% sure but I think it's a substitute for octane. It prevents detonation in that way. It also burns cleaner. However, it's not as powerful as octane.
Old Nov 30, 2002 | 07:44 AM
eclipse spanker
[QUOTE]Originally posted by Laserguided
Ethanol alcohol is a common additive in gasoline. I'm not 100% sure but I think it's a substitute for octane. It prevents detonation in that way. It also burns cleaner. However, it's not as powerful as octane. [/QUOTE
Octane is more powerful, but i meant using it as an air cooling agent, not as a substitute for gas......
Old Nov 30, 2002 | 10:06 AM
qtiger's Avatar
qtiger
It doesn't cool the air much unless you have a force inducted engine. However, it will relieve cylinder pressures and cool the engine directly.
Old Dec 1, 2002 | 12:46 PM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
I would think nitrous/aquamist system would do a better job of cooling down your car...what's your physical reasoning behind using alcohol? Eventually when our petroleum supplies run out (+- 50 years) we may turn to alcohol as a substitute fuel (Buddy of mine at Cornell was part of the team that created a SUV that ran on alcohol). But I'm still not sure why you would use alcohol over the existing systems that are out there. Plus, water is slightly cheaper than alky
Shingo
