Regular Scheduled Maintanence
Old Nov 18, 2002 | 10:40 AM
jclau00's Avatar
jclau00
Originally posted by lucgirl79
I'm looking into NGK spark plugs and found regular and platinum. What are the differences and how do I know which one I want or need?
platinums last longer, but coppers provide a better spark. go with the coppers. i believe they were NGK 2262 or somethin. they come pregapped, so just remove the old ones and stick in the new ones. i went to kragen, told them i had a 99 integra LS and they got me the plugs i needed. all for 7$.
Old Nov 18, 2002 | 12:37 PM
antarius's Avatar
antarius
Large Member
You need one.
It's like $2.00 at kragens or autozone.
Old Nov 18, 2002 | 12:41 PM
airon's Avatar
airon
AARONNOJIMA.COM
usually you should just check the gapping jsut because
Old Nov 18, 2002 | 02:13 PM
LT's Avatar
LT
The deer had to die!
LS NGK V-Power's are:
stock number: 2262
ZFR5f-11
Old Nov 18, 2002 | 04:04 PM
95TEGyoure it's Avatar
95TEGyoure it
Billy Sexcrime
wow you have a lot to do, but listen to FatBooty
i'd go with changing the oil every three months, if you don't hit 3k miles before that...oh and where in chicago are you located? i'm from IL too
Old Nov 18, 2002 | 05:02 PM
lucgirl79's Avatar
lucgirl79
95TEGyoure it: yeah i've begun ordering parts online, do-it-yourself stuff. and i found a shop that'll do my timing belt this week so i'm all good for now. i'm actually from westchester but i'm also staying in chicago because i go to school and work in the area.
Old Nov 18, 2002 | 06:18 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
You should have the water pump replaced at the same time as the timing belt. The belt has to be removed to replace the pump and you'll save a lot on labor costs if you do both at the same time.
Old Nov 18, 2002 | 06:23 PM
lucgirl79's Avatar
lucgirl79
You're absolutely right. I'm planning on doing it that way in a few days Thanks for your advice.
