Redline'n
Old Oct 23, 2002 | 10:49 AM
  #41
cdowney00's Avatar
cdowney00
Redline is that the beginning of the red the red or the end.... I hit the beginning part 6000 rpm 4-5 times daily never ever go past that too scared.... Where is the point were extra rpm diminishes horsepower(back side of the power curve)?
Old Oct 23, 2002 | 10:54 AM
  #42
DVPGSR's Avatar
DVPGSR
I need sleep...
On a stock motor you should never hit the back of the red, you may get somewhere into the red occasionally but you should not get into it often.
As for DYNO plot where the HP falls off that is where they hit the clutch to change into 2nd because they are hitting their redline!
Old Oct 23, 2002 | 01:29 PM
  #43
jgrotkier's Avatar
jgrotkier
AIM SN: Johann14420
Originally posted by crash
i acidently took my stock gsr to 10,000 once,i felt so bad i barley drove it for a week
:bs: :slap:
Old Oct 23, 2002 | 01:53 PM
  #44
Weston's Avatar
Weston
I've done it constantly and have otherwise driven it hard for the past 50k miles that I've had it and have had absolutely zero problems a as result. It still runs like new. I even accidently misshifted and hit 8k once.
It is true that your power really drops off after 6k on a LS, but it's still beneficial to shift in the red because staying in the lower gear delivers more torque to the wheels. I'm not sure what the optimal shift point is for a stock LS, but based on the dyno of my LS with I/H/E, shifting at approximately 7100 rpm will deliver the most torque to the wheels. That's based on my engine's torque output up to 7200 rpm, gear / final drive ratios, and the calculated actual torque at the wheels (the dyno plot factors out the effect of gearing, but I put it back in).
Old Oct 23, 2002 | 02:06 PM
  #45
DB7 2.0's Avatar
DB7 2.0
Banned
when i was cam'd with my b18b, 7k rpm was my best friend... these days i only take it up to about 6k if i want to pass someone
Old Oct 23, 2002 | 02:10 PM
  #46
KKTPP's Avatar
KKTPP
redline daily.. just love shifting from 3rd to 4th.. right at 7100 rpm in my ls. :P
fun fun fun
Old Oct 23, 2002 | 04:02 PM
  #47
ur31337's Avatar
ur31337
Colby
The LS was definately in need of 7100 rpm shifts when you needed power.
Old Oct 25, 2002 | 09:53 AM
  #48
sillyd's Avatar
sillyd
I know this doesn't really count because i drive a civic ('97), but i redline every gear, every shift, every day. Hasn't blown up yet 80000miles
Old Oct 25, 2002 | 03:00 PM
  #49
genks's Avatar
genks
i hit the red stuff about every other day,at least a couple of times. its just to hard to resist. i thought i was realy beatin up on my car,but now i don't feel so bad
