need help changing my manual transmission fluid on my 92 teg
Old Nov 18, 2007 | 05:58 PM
mtrivera's Avatar
mtrivera
Default need help changing my manual transmission fluid on my 92 teg
Was wondering how I drain nd fill my transmission fluid? Its feeling very stiff when I shift gears nd grinds
Old Nov 19, 2007 | 08:27 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
There are 2 plugs on the fender side of the transmission, the bottom one is the drain and the top one is the fill/check plug.
- Unscrew both plugs(fill plug first) then let the oil drain out.
- Screw the bottom plug on and tighten
- Fill case from fill plug hole until oil comes out(almost like you're over filling it)
- Screw the top plug on and tighten after the oil stops dripping out and you're done.
Old Nov 19, 2007 | 09:33 AM
mtrivera's Avatar
mtrivera
whats the transmission fluid i should use
Old Nov 19, 2007 | 09:58 AM
Lynxs1981's Avatar
Lynxs1981
You can buy the Honda brand stuff, or just regular automatic tranny fluid. I run DEX3 in mine.
Old Nov 19, 2007 | 10:17 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
I sure hope you have an automatic transmission. :noes:
Old Nov 19, 2007 | 12:15 PM
Lynxs1981's Avatar
Lynxs1981
That's what my manual says to use so I do.
Old Nov 19, 2007 | 01:34 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
To keep things simple, Honda MTF from the dealer. Nothing else.
Old Nov 19, 2007 | 03:35 PM
Provocateur
On permanent hiatus
Your manual does not tell you to put ATF in a manual gearbox. You need to drain that out immediately and put MTF in there.
Old Nov 19, 2007 | 06:47 PM
Lynxs1981's Avatar
Lynxs1981
My apologies, I was incorrect in that statement. I just rechecked my owners manual and it says you can use 10w-30 or 10w-40.
Old Nov 19, 2007 | 08:11 PM
mtrivera's Avatar
mtrivera
I have a manual car not an auto is it the same?
