Do I need an alignment?
Old Oct 2, 2007 | 01:21 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
If the tech didn't screw with the tie-rods or any cam-bolts or any adjustment point for the alignment on your suspension for the bearing install then you don't need an alignment. Period.
Old Oct 3, 2007 | 07:56 AM
bnuk's Avatar
bnuk
i dunno for a wheel bearing it might be a good idea, they would have unhooked the tie rod and if it gets turned at or the adjusting nut gets changed your allignment will be off.
As far as wheels, that bullshit. allignement is independant of the wheels unless you are running 15s on one side 17s on the other. Think about your car sitting on a flat surface and then think about it on the same surface with 1" boards under each wheel. the suspension is going to be unaffected.
Old Oct 4, 2007 | 04:06 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Anytime I replace tires I do an alignment, it just helps you get the most out of them.
Old Oct 6, 2007 | 12:03 PM
Taiwanze7's Avatar
Taiwanze7
You should get an alignment if you're changing/fixing/modifying the suspension, axles, steering.
Old Oct 6, 2007 | 02:57 PM
Chiovnidca's Avatar
Chiovnidca
SOHC Powered
The act of replacing a wheel bearing on a honda shouldn't change the alignment. That doesn't mean you dont need one though.
Old Oct 10, 2007 | 07:12 PM
Spec R's Avatar
Spec R
Originally Posted by gc94GSR
If your car doesn't pull at all, either to the right or left when going straight on a level road then I would say that an alignment is not necessary.
wrong.
even if the car drives straight, there are other factors in the suspension that wont cause pulling drifting shimmy etc that are immediately noticable by the driver.
throw it on the rack anyway.
DB Squad
Integra Forum Moderator
