EXHAUST problem
Old Sep 15, 2007 | 12:51 PM
politepilljocky's Avatar
politepilljocky
Default EXHAUST problem
MY EXHAUST is leaking water from under in its getting rust its a small hole its not that big but i need help how do i fix this problem. i dont want it gething more rust and no water leaks i know how i got it, the street humps on every street i keep scraping it, maybe thats how i got the small hole i looked under the car in it does have rust i just want to know how to keep it from leaking water in do something about the rust help out thanx alot
Old Sep 15, 2007 | 01:52 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
If you have water in your exhaust in excess of normal condensation, something is very wrong with your engine and the rusting exhaust should be the least of your problems. So, how much water are we talking here?
To fix it, you would obviously take it to a muffler shop and have them weld it shut or weld a new piece in to replace the rusted section(s).
Old Sep 16, 2007 | 07:54 AM
politepilljocky
not that much water comes out like drops only then it stops, well my car has been sithing in my drive way for long period of time i just move it 2 times a week when i drive it it makes no sounds or nothing out of the ordinary it drives like a champ what do u think it is?
Old Sep 16, 2007 | 09:11 AM
politepilljocky
i fix the leak in the rust part i was woundering about what you told me about the water part now? today i turn my car on its like if the exhaust spits the water out then it stops not alot only for like 30second, by the way the catalytic converter is guetted out(i know iam polluting) can that be the problem what do u think?
Old Sep 17, 2007 | 05:53 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Is it possible that his cat is kicking so much ass that what we normally see dripping out of the tailpipe is coming though a hole sooner than that?
Old Sep 17, 2007 | 07:12 PM
politepilljocky
What?
Old Sep 17, 2007 | 08:07 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Originally Posted by politepilljocky
What?
If your catalytic converter is working well, condensation will be visible from the tailpipe exit and will actually form a drip. Where is your leak visible from?
Old Sep 17, 2007 | 09:03 PM
Provocateur
On permanent hiatus
Water is a natural byproduct of combustion from the engine, not the catalytic converter. NOx is broken down into nitrogen and oxygen and carbon monoxide into carbon dioxide and oxygen by the catalytic elements. Water is not a byproduct of these reactions.
It sounds to me like normal condensation that has built up inside the piping.
Old Sep 18, 2007 | 05:58 PM
politepilljocky
so there is nothing rong whit my engine? its my cat doing it ?
Old Sep 18, 2007 | 07:11 PM
RPMthingy's Avatar
RPMthingy
When your engine burns fuel and air, part of the exhaust is water vapor. That's the plume of vapor you see exiting the tail pipe. The rust is probably from scratches on the outside. The metal won't really rust in just pure water. It needs salt, and the muffler only really gets exposed to salt from the outside.
