Vibration upon acceleration
Old May 20, 2007 | 08:44 PM
kevyt's Avatar
kevyt
Default Vibration upon acceleration
I have a 96 gsr with 239K miles and it runs awesome but it has vibration when I press on the accelerator. The vibration happens as soon as I press on the pedal slightly. Then the vibration stops when I let off of the pedal.
I have installed 2 front tires, 4 brembo rotors (fixed the braking vibration), Akebono pads, ss lines, and gotten an alignment. So, it's not the rotors or tires (were balanced). The rear tires WERE cupped on the inner edge but now I have the old front tires on the rear and they are fine.
I don't think it is the axles or CV joints because it does not vibrate unless I touch the gas pedal and the axles are always spinning regardless if I am pressing on the pedal or not. I also think the mounts are fine because I replaced 2 last year. I glanced at the mounts tonight and they looked ok, but I only made a quick glance.
I also changed all of the shocks last year and the 2 front wheel bearings. I don't think that it's the wheel bearings because they made a very loud noise when they were bad.
Do you have any idea? I looked in other forums but I did not see anything exactly like this.
Thanks
Old May 20, 2007 | 09:00 PM
guitarswheelies's Avatar
guitarswheelies
check out my post. I have a similar problem. Do this happen mostly around 40mph, and when going uphill? I can accelerate a full throttle in first gear and it doesn't shake, but when you hit 40 in second (or third) its pretty rough
Old May 20, 2007 | 09:28 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Inboard CV joints. Stuck the car up in the air, start it, put it in gear, and examine the inboard joints. Most likely, one will be wobbling.
Old May 20, 2007 | 10:47 PM
lazieb29's Avatar
lazieb29
where do you feel the vibration??
Old May 21, 2007 | 05:02 AM
kevyt's Avatar
kevyt
I will look at the inner joints today. I feel most of it in the steering wheel. I dont notice it at 40 mph but I do at 50 - 55 mph. I also did not notice it when going downhill.
Old May 21, 2007 | 08:54 AM
kevyt's Avatar
kevyt
I just drove it 140 miles and I noticed vibration in the floor also. I think the suggestion above is right. I think it is an inner CV. I don't think it is an outer CV because I don't have clicking noises while turning at low speeds.
Old May 21, 2007 | 08:55 AM
lazieb29's Avatar
lazieb29
yea man sounds like your inner joints.
Old May 21, 2007 | 09:06 AM
Provocateur
On permanent hiatus
That would be the first thing I would check. I had the same problem and ran through the same diagnosis as you with the same result. A set of new axles fixed everything up (and by new, I don't mean POS autozone axles).
Old May 21, 2007 | 09:22 AM
lazieb29's Avatar
lazieb29
you can order beck-arnley from autozone
Old May 21, 2007 | 10:28 AM
kevyt's Avatar
kevyt
lol - I have gotten junk from the local auto parts stores. What brand do you recommend? I have changed axles on a 95 prelude before. I assume these will have the same level of ease to replace?
autopartswarehouse.com has EMPI, First Equipment Quality, and CVU.
I will take look at them within the next few hours.
Thanks for all of your help!
Kevin
