CEL Code 67
Old May 20, 2007 | 09:20 AM
Try2Live4God's Avatar
Try2Live4God
Default CEL Code 67
I checked my CEL and it's telling me code 67. I do know it means:
Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
Does that mean the cat is malfunctioning? Does this mean I need to check the cat again?
Old May 20, 2007 | 10:28 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
You'll probably need to replace the cat because the secondary o2 sensor is reading high levels of emmisions coming out of the cat that shouldn't be.
Old May 20, 2007 | 08:06 PM
Try2Live4God
Hmm....and it's a brand new SMSP cat....
That sucks!
Old May 20, 2007 | 08:32 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
That sucks!
Is it a high flow cat?
Old May 20, 2007 | 09:36 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
If you want to get rid of the code for that high flow cat, you are going to either run an O2 simulator or convert to OBD1.
Old May 21, 2007 | 02:55 AM
Try2Live4God
Yes it is a high flow cat....
What is an O2 simulator? And why would I have to do do this?
Old May 21, 2007 | 09:11 AM
Provocateur
On permanent hiatus
It is pretty self explanatory. It simulates an O2 sensor signal to fool the computer into thinking everything is ok.
Since you are still running OBD2 and the cat you replaced the stock one with isn't sufficient, it will throw a code every time. OBD2 is picky, so you need to eliminate the secondary o2 sensor somehow to get rid of the code.
Old May 21, 2007 | 02:53 PM
Try2Live4God
Ooohh....ok. No wonder I hear about OBD2 folks wanting to convert to OBD1.
Old Jun 6, 2007 | 05:48 AM
Try2Live4God
What would I need to convert to OBDI?
Old Jun 6, 2007 | 10:30 AM
Provocateur
On permanent hiatus
An OBD2b (since it is a 01 GSR, correct?) to OBD1 conversion harness and a P72 ECU. You could use any vtec ECU but they won't be able to control the secondaries and a P28 board doesn't have knock sensor control.
