CEL Code 67
Old Jun 8, 2007 | 07:44 AM
Try2Live4God's Avatar
Try2Live4God
Originally Posted by Provocateur
An OBD2b (since it is a 01 GSR, correct?) to OBD1 conversion harness and a P72 ECU. You could use any vtec ECU but they won't be able to control the secondaries and a P28 board doesn't have knock sensor control.
Thanks for taking the time to reply!!
Is the P72 a GSR ECU? And what years do this ECU come from?
Old Jun 8, 2007 | 10:15 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
The P72 is the GSR ECU. It is available from 94-01 in OBD1 and OBD2.
Old Jun 8, 2007 | 10:57 AM
94civicEX's Avatar
94civicEX
I got worms.
I'd just get an O2 simulator, you run into the same issue when you run a test pipe as well.
99 Integra GSR
06 TSX
duck squad member #00003
Old Jun 8, 2007 | 12:35 PM
bnuk's Avatar
bnuk
btw, chances are if its called a "high flow cat" it is just a peice of pipe.
Old Jun 8, 2007 | 03:42 PM
Provocateur
On permanent hiatus
Yeah, if you buy an ebay special. A carsound (magnaflow) cat is definitely not a test pipe.
Old Jun 8, 2007 | 07:52 PM
bnuk's Avatar
bnuk
I believe that is the only one with any kind of catalyst in it. i feel like there might be one other one but it's pretty steep.
Old Jun 11, 2007 | 03:31 AM
Try2Live4God
What does the simulator do? And where do you get one?
Old Jun 11, 2007 | 09:10 PM
Provocateur
On permanent hiatus
Google is your friend.
This took me 3 seconds to find: http://webstore.o2simulator.com/
