new skunk2 mani + 73mm TB...running RICH!!??
That doesn't mean that one big enough to fit your head through is the solution to that problem.
As long as everything is hooked up correctly and you aren't throwing a CEL, the car probably needs to be retuned for that overkill throttle body and manifold.
What kind of tuning needs to be done? why would it be running rich, I would have thought lean...
The TPS on my GSR is blue, and the MAP connector is black.
If you look at the wiring diagrams in the back of a haynes or helms for your car, they will list the colors of the wires that go to each connector.
and if you didnt portmatch the manifold to the tb you're creating a big bottleneck. the opening on the s2 manifold is 65mm i believe.
bigger does not always mean better, this cannot be more true when talking about tb's. the stock one isnt much of a restriction until you start making big numbers.
The FITV is located on the bottom of your throttle body, and the IACV is located on the rear of the intake manifold. At some point, the FITV and IACV were combined into one unit which mounts to the rear of the Intake Manifold.
If your old setup did not have the issues your experiencing now, try eliminating the FITV. If you still have the same issues, you might need to switch back to your old TB until you have a tunning solution.
