new skunk2 mani + 73mm TB...running RICH!!??
Apr 6, 2007 | 10:46 PM
I just put my skunk2 intake manifold on my 1995 Integra LS engine with a 73mm DH Racing Throttle Body. The car is running extremely rich, any ideas why?? Do I need to get it tuned for such a little mod?
Apr 6, 2007 | 11:51 PM
Are you sure that all the sensors are hooked up just as they were removed?
Apr 7, 2007 | 12:17 AM
Yeah, double check the sensors, and absolutely check all the vacuum lines. Vacuum lines hooked up the wrong way will cause rich/sputtering conditions.
Apr 7, 2007 | 11:29 AM
why did you put such a huge tb on there?
Apr 7, 2007 | 12:28 PM
Quote:
Originally Posted by
Snoopy
that is what i was wondering too, but def check the connections
Apr 7, 2007 | 01:47 PM
Namely the MAP and TPS connectors. The clips are identical, and when reversed will cause all sorts of problems.
Apr 7, 2007 | 02:14 PM
yeah its sputtering and running very rich!
is there any way to tell the difference from map and tps connectors, if there the same plug??
Apr 7, 2007 | 02:15 PM
Snoopy
I got a deal on it, is 73mm not good for my motor?
Apr 7, 2007 | 02:17 PM
jdmeg6hatchy
looks like you only have bolt on's. stock is fine for that. did you even portmatch the manifold to the tb?
i would only use 73mm on a serious all motor or boost engine
Apr 7, 2007 | 08:36 PM
Snoopy
my stock throttle body was messed up.
