Tire question
Old Mar 29, 2007 | 01:24 PM
dubcac's Avatar
dubcac
I
Originally Posted by TheOtherDave™
He's dead wrong.
205/45R16 is the correct size to preserve the original rolling diameter of the wheel. I'm a tiny bit skeptical of the +40 offset as well, because my 16x6" rims are a +42 offset.
Worst case scenario.. if you do rub with a +40 rim, a set of 3 or 5 mm hubspacers and longer wheel studs will solve your problem.
Using hubspacers will just put him closer to the fender.
Old Mar 29, 2007 | 02:50 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Oh shit... you're right.
It would appear that I can't count. h:
+40 is shallower than +42.
Old Mar 29, 2007 | 03:18 PM
nsxtasy's Avatar
nsxtasy
He's dead wrong.
You can also use 215/45-16. Both sizes are within 1 percent of the stock outer diameter. With the proper offset on your wheels, neither should rub.
Old Mar 29, 2007 | 03:42 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
I had 205/45/16's on my Integra at one time w/a 2 inch drop and it never rubbed.
