major antifreeze leak
Old Feb 8, 2007 | 08:02 AM
gta4life's Avatar
gta4life
Default major antifreeze leak
welll, just last night while i was driving home i noticed my car was making what sounds kind of like a bubbling sound coming from the engine compartmentt so when i looked under i noticed that i had a huge antifreeze leak, so i stopped off immediately and bought some antifreeze to put in, and while i was adding it, it was just coming right out, so im wondering if its more likely to be a hose or possibly my water pump? also what could be making the bubbling noise that im hearing? any opinions? thanks
Old Feb 8, 2007 | 08:12 AM
bnuk's Avatar
bnuk
should be pretty obvious if its bad but the most common problem is the plastic ends radiator develop cracks that open up under heat/pressure.
Old Feb 8, 2007 | 08:19 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Copy that. I'm on my second radiator.
Old Feb 8, 2007 | 08:26 AM
gta4life's Avatar
gta4life
how would it be obvious if the water pump was bad? and if it is the water pump how much is that to fix? i know the timing belt is a pain in the A$$ so i assume the water pump is a big job to?
Old Feb 8, 2007 | 08:48 AM
fjm1's Avatar
fjm1
G35
you need to find out where it is leaking from.
Old Feb 8, 2007 | 11:31 AM
jesusublime99's Avatar
jesusublime99
If you cannot pinpoint where the leak is coming from, you can take it to a repair shop and ask them to do a simple radiator pressure test, you should be able to watch. I have one of these testers, it always comes in handy. Changing the water pump requires removal of the timing belt, so its just like doing a complete timing belt job.
I don't know of an easy way to tell if your water pump has gone bad, but i don't think coolant would be gushing out. Also, the water pump is on the timing belt side- look under the car- where is the coolant coming from? Tranny side or timing belt side?
Old Feb 8, 2007 | 05:28 PM
gta4life's Avatar
gta4life
heyy yahh its coming from the timing belt sidee, and yahh me and my dad tried putting in more antifreeze and it just starts coming out right away, we cant exactly pinpoint it yet all we know is its on the timing belt side at this time
Old Feb 9, 2007 | 03:34 AM
bnuk's Avatar
bnuk
sounds like a real pain in the ass... I guess your next step will be to take off the valve cover so you can get the timing belt cover off then replace he valve cover and plugs and start it up and [carefully] see where the leak is.
Old Feb 9, 2007 | 06:25 PM
MC-14's Avatar
MC-14
Tri-man
Your water pump is no good for sure if it is coming from the timing belt side. No need to tear it apart to see. Bubbling noise usually means you have air in the system due to the leak.
