Tegs Coming Back...some Help Needed
Old Oct 19, 2006 | 02:09 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Originally Posted by rugsr
i use mobil 1 oil filter
drop im MPG...is this due to thicker oil. it puts more strain on the motor?
why doesnt everyone just go with 10w to be safe...why bother with 5w
I'm no engineer... but the primary benefit with 10w30 over 5w30 is that 10w30 will flow better at subfreezing temperatures.
I assume that increase in low-temperature flow performance comes at the detriment of overall viscosity and therefore, slightly increased drag / fuel consumption.
Keep in mind we're talking about very slim margins here.
It's not like 5w30 is water and 10w30 is like cement.
And to answer your broad question, I use 5w30 because I never see the subfreezing temperatures where 10w30 provides additional protection.
Also, this isn't new news. The Owner's Manual and HELMS Factory Service Manual both discuss the use of 10w30 in cold climates. :shrug:
Old Oct 19, 2006 | 02:17 PM
Snoopy's Avatar
Snoopy
been there done that
:werd:
im using 5w30 in my b18c1. heck my brother even used 0w40 mobil 1 in his gsr for a while.
Old Oct 19, 2006 | 03:13 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The difference between 5w30 and 10w30 is so negligible, it isn't even worth discussing. I have regularly switched between the two and I have seen no difference in performance.
But since you are asking, I am using 5w30 at the moment. h:
Old Oct 19, 2006 | 03:55 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
So where did the oil go?
Old Oct 19, 2006 | 05:16 PM
Brar's Avatar
Brar
you probably drained it after getting it running, planning to change it. Then you got the s2k and forgot all about it.
Old Oct 20, 2006 | 05:13 AM
rugsr's Avatar
rugsr
How do my taillights look
Just picked up 10w-30...4qts ran me $20.73 and I have 1/2 qt left over from spring. I plan on pulling the plug and seeing if ANY OIL comes out.
1)Fill the girl up with some oil
2)Relocate both slim fans to other side of radiator to make more room (like Daschmoo =) )
3) Fill with radiator fluid
4) Check my spark plug gaps. If I can remember Daschmoo. Gap them to .25?
5) Turn the key and go
OH I CAN HEAR IT NOW...weeedeeedeeee WHOOOOMMMMM
For those of you who are new, this was taken last spring right after I did my custom turbo install
ENJOY
http://wtflip.com/vid/core4/imagepages/image4.html
Old Oct 20, 2006 | 01:12 PM
Provocateur
On permanent hiatus
ENJOY
:werd: on the fans.
Gap the plugs to .030". .025" won't hurt, but it puts unnecessary strain on the ignitor if you don't need the gaps that low.
Old Oct 20, 2006 | 07:51 PM
FooD2000's Avatar
FooD2000
Still Water
Bottle of "heet" to help with your nasty fuel.
Old Oct 24, 2006 | 04:03 AM
rugsr's Avatar
rugsr
Well...it started right up...I had about 2qts in there, so I drained it then put 4.5qts of new Mobil 1 10W30 in her. I then moved the fans (which might I add look way better hidden) and filled her up with Radiator fluid. She started right up.
I let her warm up and then took her for a spin. Lets just say at 50-60mph in 2nd the tires were spinning when I hit full boost. HAHA, i started laughing my ass off, I forgot how the turbo feels since I got the S2000.
NEXT QUESTION GENTS: I installed a ACT HDSS clutch and a 8lb Findenza. Before I put the teg away I thought the clutch pedal was great...but when I drove it last night the clutch engauged and dis-engauged at about 90% of its travel. I COULD HAVE SWORN it was the other way around, Before I put it away I thought it was E and dis-E at about 10-15% travel...something wrong?
