Need help with integra shocks
Old Aug 2, 2006 | 09:49 PM
wmartir123's Avatar
wmartir123
Default Need help with integra shocks
i have an 96 integra and i tried to change the shocks and when i got to the screw that goes through the axle and holds up the shock it wouldnt come out it came out alittle but it wont budge any more i never done this before so idont know what to do hit me up ASAP and let me know thanx =) check out the pics under this
Old Aug 2, 2006 | 09:53 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Dude you need to undo the assembly right above the fork to separate it and give you some play, then place a jack under the bolt area and push it up just a little to free some weight off the bolt.
Old Aug 2, 2006 | 10:22 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Use a hammer and punch to get it out.
Old Aug 2, 2006 | 10:43 PM
dmacaalay's Avatar
dmacaalay
Monkey See, Monkey Do!
Default ^^^ what he said..
or you can use a flat head screwdriver.. skinny enough to fit through the hole.. just make sure you line it up straight..
Old Aug 3, 2006 | 09:11 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Or could do that. Won't he still need to separate the assembly to get it out? It is a bitch for me in 1 piece.
Old Aug 3, 2006 | 10:19 PM
Integra89's Avatar
Integra89
i had the same problem my father just cut the for and then drilled the bushing out and bought another screw... it wokred but took some time
Old Aug 4, 2006 | 08:33 AM
bnuk's Avatar
bnuk
yeah just get something long and skinny and tap it out. If it starts to get stuck, try to unscrew it again.
also the reason it is hard to get out is that those holes through the bushings are made to line up when the suspension is compressed, when it hangs down it binds on that bolt. what you can do take another jack and push up on the fork (not the LCA, that will just make it worse) that will help some too.
Old Aug 4, 2006 | 09:47 AM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
you do realize that the fork is threaded on both sides.... so you turn it.... pull it... then turn it again
Old Aug 4, 2006 | 10:30 AM
bnuk's Avatar
bnuk
no its not.
