I need a new motor....
Old Jun 22, 2006 | 12:09 AM
Phateless's Avatar
Phateless
S2K compatible
why not just replace your cams then?
Old Jun 22, 2006 | 10:28 AM
dubcac's Avatar
dubcac
I
Originally Posted by JoePoonani
I'm talking about the wear on the lobes. They're starting to get a little round.
Edit: and my valves are really noisey.
1. I doubt that.
2. Adjust your valves.
Done.
Old Jun 22, 2006 | 01:08 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
I checked all the valve clearances and they are all in check to specs.
Old Jun 22, 2006 | 02:23 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Why waste 300 or so on some cams when I can put the money toward a new motor?
Old Jun 22, 2006 | 03:22 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
I really want the B20 sooooo bad. What would I need to do to convert to OBD1? Alternator, starter, dizzy, intake mani? Would I be able to use my existing harness and ECU with the converted B20? Hmotors sells them for 650 and Password is selling them for 550 vs the 750+ for the B18B
Old Jun 22, 2006 | 04:00 PM
reno96teg's Avatar
adjust your valves again. have you done a compression test?
Old Jun 22, 2006 | 04:06 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
I haven't done a compression test yet on it, I will do it soon though.
Old Jun 22, 2006 | 05:06 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Screw it, I'll just get the B18B then. :sigh:
Old Jun 22, 2006 | 06:32 PM
boehmdw97's Avatar
boehmdw97
the b20 will bolt right up and give you more power. The engine is less money also. If you wanna turbo, get the b20b, if NA then try to get the b20z. They are good motors and again, it WILL all bolt right up to the set up you have now.
Old Jun 22, 2006 | 06:39 PM
Phateless's Avatar
Phateless
S2K compatible
if you REALLY wanna go fast, go with the b20 motor and the b16 lsd tranny.
